Concrete pile question
Tom Sestito
Winnipeg, MB
Good afternoon,
I am installing a grade beam for a cantilever gate behind my garage.
It requires two 16" piles, 6' down. I had those drilled last week when the ground was still frozen.
The contractor used a 17.5" drill bit.
Because the ground was frozen, the edges of the holes turned to muck. The debris and muck resulted in the overall diameter of the hole being quite a bit less than my sonotube.
So, I slit the sonotube with a skillsaw and dropped them in the hole and carried on.
However, they have retained the 'new' diameter - closer to 14".
I suspect they will expand back to close to their original diameter.
My question is - has anyone done this before and am I correct that the tubes will expand back?
I need this info to ensure I order the correct amount of concrete.
Thoughts or experience would help. Thanks all.
Marctrees
TX/LA border - Toledo Bend
I'm sure the weight of the concrete will open up the tubes...
BUT you will have air gaps like everywhere between tube and dirt wall.
I see no benefit for tubes in this situation.
Having done similar to your job, I poured w NO tubes.
Concrete ends up totally intimate w packed virgin soil.
My opinion , NOT Pro engineer.
Marc
T
Tom Sestito
Winnipeg, MB
Concrete ends up totally intimate w soil.
Marc
Thanks for the reply, I had considered leaving the tubes out but with the 4' of frost we get I was concerned about heaving overtime, with the rough edges of the holes.
No expert either though!!
Marctrees
See, you have a very good question I think, because in frost country.
I would want a Pro to answer it if was me.
Marc
jhelrey
MN
We only use tubes for the first 12 or so inches... then the rest is dirt.
joes169
WI
You'll certainly want sono tubes to keep the columns smooth so that frost can't pick at the edges. I'd simply order for 16" diameter, even round up 10-15% to be safe, and hope that they expand that much. W/o actually seeing the conditions in person, it'salmost impossible to guess how large they're going to get when they're poured.
didit
S.W. Ontario
I usually have a form ready where ever needed to use any left over concrete. I think if you tamp it as you go with an appropriate diameter ram, those tubes will expand to their original size.
T
Tom Sestito
Winnipeg, MB
Thanks all. I calculated the weight of the concrete- each tube (there are two) will weigh ~900 lbs and the beam itself above the tubes will weight ~5,000lbs.
So there will be a lot of pressure to expand them.
I will have a spare form ready in case I have too much concrete - this is an excellent idea.
