Tom Sestito
Good afternoon,
I am installing a grade beam for a cantilever gate behind my garage.
It requires two 16" piles, 6' down. I had those drilled last week when the ground was still frozen.
The contractor used a 17.5" drill bit.
Because the ground was frozen, the edges of the holes turned to muck. The debris and muck resulted in the overall diameter of the hole being quite a bit less than my sonotube.
So, I slit the sonotube with a skillsaw and dropped them in the hole and carried on.
However, they have retained the 'new' diameter - closer to 14".
I suspect they will expand back to close to their original diameter.
My question is - has anyone done this before and am I correct that the tubes will expand back?
I need this info to ensure I order the correct amount of concrete.
Thoughts or experience would help. Thanks all.
