jonathan75
I finally have almost everything I need to pressure test my spare parts and pull a vacuum. I want to keep the best one for myself and sell the rest. This week I got in a used JB vacuum pump and a nitrogen kit.
What is the best way for me to seal off the evaporator and condenser for testing. I want to leave it under pressure with nitrogen while storing it after testing also. How should I do this? Do I braze a cap on one side and get a T connection with a schrader valve on the other side? If so do I cap the larger or the smaller pipe?
Also the condenser units have been sitting outside with the ends cut open. Should I blow it out with nitrogen to make sure nothing is inside or should I try and vacuum the dirt out first at the end where the pipe is cut off?
