conduit question
supratreo
elk grove, CA
hi, quick question for you all. i'm running some NM form a in-wall panel, up through the ceiling and dropping it down about 30' away. only issue is that i have a huge header on that side so i'm not able to drop it in the wall, it would have to be through the ceiling and along the wall. this is all on the interior of the building. i've read that you can not run NM through conduit so what would i have to do to protect/enclose the wire, if anything? the wire will def. be safe from any damage but i would rather not have wire just exposed like that if possible.
thank you
Norcal
If short sections of conduit are used to protect NM cable that is fine but to put the whole run in conduit is a huge pain in the azz.
supratreo
elk grove, CA
got it. thank you. it will be about 2-3' of straight conduit. wood would be more work than its worth i think. its only one cable.
BreeStephany
Oregon
Run the NMB in the enclosed space from the panel as far as you can, pop it through a romex clamp into the back of a 4 square surface mounted box, then switch over to THHN stranded conductors for the length of your conduit run, then switch back to NMB where it drops back into the wall.
Just my two cents.
Innovate1
Most places will accept just a runner board next to the NM as protection. No need to completely enclose. But conduit also works. With PVC just knock the sharp edge off the inside of the ends and no need for any other things.
supratreo
elk grove, CA
Almost forgot, they make plastic bushings for the emt ends to protect the NM from getting damaged.
i got a few of those ready but thank you for the reminder.
trying not to have to splice anything if i dont have to. wire will not be running back into the wall after it pops out of the ceiling.
sparky 1971
Central Iowa
This is an official EMT to romex fitting.
I hate those effing things though. I just use an EMT set screw coupling. They have a nice round edge so if the romex does wind up against it, nothing bad will happen.
supratreo
elk grove, CA
thank you for the replies. type of conduit doesnt really matter. i was thinking EMT but i think i have some 1" pvc laying around do i'll probably just use that. would i still need a bushing or can i just knock off the sharp inside edge?
mike93lx
Richmond, VA
You need a bushing or something that provides the same protection, like a box adapter.
I use bushings for all conduit installs so there is no debate if I should have used one or not
Innovate1
Like knocking the sharp edge off the inside edge of the PVC cut end. It seems to me this is something the local AHJ may interpret differently so if this is being inspected probably safest to ask or use a bushing or box adapter but practically it seems unnecessary.
nh_yota
Seacoast New Hampshire
You can definitely run NM in conduit - as long as it's in a dry location. I think a lot of the "can't run NM In conduit" confusion comes from the fact that you can't run NM in conduit in a wet location. Conduit doesn't magically change a wet location into a dry location.
mike93lx
Richmond, VA
No argument there. It's a PIA to add one after, so I just put one in at the beginning.
supratreo
elk grove, CA
i wasn't aware of the wet vs dry usage. from what i've read its more if a heat dissipation issue. stating that NM needs to be in "free air" to dissipate heat as its wrapped so tight where loose wire in conduit has plenty of room. this is just from what i've read here, seems logical tho.
sparky 1971
Central Iowa
The heat issue is taken care of by treating NM as TW using the 60° column of 310,16 even though the conductors have 90° (THHN) insulation.
yeah no such issue
