supratreo
hi, quick question for you all. i'm running some NM form a in-wall panel, up through the ceiling and dropping it down about 30' away. only issue is that i have a huge header on that side so i'm not able to drop it in the wall, it would have to be through the ceiling and along the wall. this is all on the interior of the building. i've read that you can not run NM through conduit so what would i have to do to protect/enclose the wire, if anything? the wire will def. be safe from any damage but i would rather not have wire just exposed like that if possible.
thank you
thank you
