Shoester
I'm designing a 24x30x10 to fit on my modest suburban lot right next to my house.
I'm currently working through all of the pro's/con's of Post Frame vs Stick Built construction, and I'm hung up on the siding. To match my house and to appease the HOA, I have to use wood panel siding. With Pole Barn construction, will I run into any issues with 4x10 panel siding using the 'bookshelf' girts? And this may be a really stupid question, but with either method do I need to run OSB sheeting on top of the studs/girts or can I simply Tyvek the exterior on top of the studs and then install the wood panel siding on top of that?
Thanks for the help!
