Constructing a pit
MikefromNZ
New Zealand
After months of debating raising the roof or building another shed have decided to use a combination of low lift hoist and oversized pit I do mostly transmission work on fwd cars and general servicing any suggestions welcome
Sent from my SM-G390Y using Tapatalk
MikefromNZ
New Zealand
Hole is dug unfortunately found a tile drain 8d3094826301628d41f3bcfd7bf14396.jpg75adee222ad860ee81ae1d9c5c07d3b8.jpg
MikefromNZ
New Zealand
Concrete poured today 2.8 cubic metres of 200mpa 21c1d06b46dd6e10c42f0f59f1bf6896.jpg
LXCam
What did you use for reinforcement, 1/4" pencil rod? I know your pretty far along since the forms are placed but I'd highly suggest you rethink how this is tied into the existing slab and what you decided to do for the cage. Considering it appears the thickness of your walls are 3-4" I'd have gone with #4 bar 12" OC both directions but honestly and since I don't want to get blasted here with inferring bad info you should have consulted an structural engineer for a proper design.
Good luck
Jeepster04
Id like to know why a drain tile was running under the garage slab? And what did you do to fix that and keep the water out of the pit?
MikefromNZ
New Zealand
Hi it was an old tile drain from when it was farmland It was now running backwards from their property I dug it up at boundary and blocked and disconnected it no water has entered the hole since
ptschram
Churubusco, IN
Not trying to be critical and certainly not negative but how do you intend to ventilate this confined space, and how are you getting in and out?
Otherwise, I really want to do the same! But probably won't due to my shop business moving toward engine building and not "working on trucks"
MikefromNZ
New Zealand
Hey I have certainly thought about ventilation and access i think I have the location of stairs pretty well worked out but will likely use it with a ladder a few times to make sure there's nothing I've missed ventilation wise a large single phase fan ducted into the pit
MikefromNZ
New Zealand
Floors drying and hoist in place to check measurements were good looks like it will work well ladder is temporary and steel supports will hold up legs of hoist the engine support is just sitting there 2d2f9008138f156054cf15fe908b2eb0.jpg
MikefromNZ
New Zealand
After seeing all the water you need to seal it or have some way to pump water out. It is also wise to vent it in some way.
Water was from an old tile drain running backwards that has now been blocked at boundary and concreted up pit is in hard packed clay however I have installed a 25litre sump am just waiting on a internal float switch pump to go in there . Ventilation is a definite priority that I should have sorted this week thanks for the comments 16e667ebaee6f8fc97b43ddad3a4f013.jpg
ynned
N.E. Ohio
Petroleum fumes are heavier than air and will collect in the pit. Any fan or lights, etc should be explosion proof.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Where are you located?
The OP's name is MikefromNZ so I would assume New Zealand.
Am from New Zealand.
An update of your profile with a location would help you.
Also a reminder to all. Political comments in posts are against forum rules. As a member here I am not interested in Politics but I am interested in what happens with the Garage.
