Contractor screwed up, what would you do? 2 post lift question
decrepitdrew
I’m building a garage with a two post lift. Situation: Picked out a lift, sent the requirements to the GC.
Dug extra depth, 12” or more for the location of the post.
Concrete people put a expansion seam RIGHT over the middle of the footers.
I cannot move the lift forward or backward to meet the 8” clearance minimum because I have piping for radiant flooring.
I only plan to use this as a hobby lift. Will barely ever have more than 6K pounds on it.
Why I don’t want to dig up the footers and re-pour:
Tying into the existing slab risk hitting the piping with horizontal rebar.
And the monolith pour is significantly stronger than cutting up and redoing the footers
Given my intention, and the infrequent use, should I be fine installing over the expansion seam?
beltfeed
USA
A photo would really help. Also, what brand / model lift are you putting it.
D
decrepitdrew
Yes I read the manual and that’s why I’m here. I told the GC with specific instructions not to do what they did. I’m here to see if there are an experts that can take into consideration that I’ll never be anywhere near the limits of the lift.
I’m looking to avoid have them cut up and redo the two footers of at all possible.
AC-WC
NE, Indiana
Do you have a map of the radiant tubing? If not, can you do an infrared camera? Absolutely do NOT straddle an expansion joint. Yes, a picture of the seam would be helpful. Like PCCustoms said possible to do large steel plates but would need engineering approval.
Rusted Nut
Northern Arizona
What type of expansion joint? Probably could be fixed with a plate of some sort. Was the direction given to the contractor in writing?
PCustoms
VT
Here's a pic from their other thread:
Assuming the contractor has a layout/plan for those footing, seems to me they can cut out the footing and re-pour the area
LXCam
Just to confirm the footings exist where they’re supposed to be right?
How thick is the slab?
To cut this short I’d go with anchor bolts long enough to go thru the slab with the required embedment into the footing.
D
decrepitdrew
Why?
They screwed up, make them fix it.
Other option is to call the mfg and have them approve a plan
That is option number 1.
Yes, it was in the body of the email along with the link to the floor requirements. They know they messed up, but wanted to see if anyone had any additional feedback before we go tearing up the slab.
But that appears to be the only option
D
decrepitdrew
Yes, the footings are there, and close to, if not more, than 12 inches deep
kngelv
Detroit, MI
What about getting a 4-post instead of the two post? Otherwise have them fix it. They screwed it up. I have a 4-post because my current garage is 3.5" on one side and 5.5" on the other. New garage behind the house is 7.5" at the shallowest.
James
D
decrepitdrew
James
Radiant flooring and I don’t want a four post because it’s to work on cars, not store them
kngelv
Detroit, MI
I work on cars with a 4-post - no storage at all. I can do anything that anyone can do on a two post. However it does take a bit longer to set up when elevating the wheels. I was stuck because of time constraints on a job and my thin floor. This is why I just built a second garage with a 12' ceiling and a thick slab. Now I at least have the option of a two-post. Good luck.
James
AC-WC
NE, Indiana
Time for them to make it right. With written instructions you would win in court. Not that anyone wants to go that far. Hindsight is always 20/20 but I always recommend for this type of work, be onsight to prevent this type of mistake.
When I had my rework done for my lift I emailed all the instructions also and the contractor wasn't going to do it like I had written. In fairness to him he had no experience with 'technical' concrete like this just driveways/sidewalks.
I've come to the point I have to be onsite for any contractor.
D
decrepitdrew
I was home when it was done and checking on a regular basis, but didn’t see them scouring for the expansion joint.
I really do not want to break up the monolith pour, but I guess it has to be done. Atleast I won’t have to pay for it.
D
decrepitdrew
James
Curious how that works honestly.
D
decrepitdrew
Not this specific one, but I had the manual when I told them the requirements. They just flat out missed reminding the concrete people, or the GC forgot . Guess I’m cutting up new footers.
Everyone thanks for the help. I’ll be sure to post pictures of the finished product.
Jagmandave
Overland Park, Ks.
I work on both a 2 post and a 4 post, they both have their plusses and minusses, depending on what you're doing and what vehicle you're lifting. To me the 2 post is by far the most versatile......I'm always hitting my head on the ramps of the 4 post, and it seems those ramps are always in the way of what I'm trying to do, and if I have to take off a wheel it's even more work. I think they're fine for storage, and I know some people swear by them, but I mostly swear AT the one I use......
PT Doc
Needs change over time and many people add equipment that requires thicker concrete. Look at the retrofit drawings from the manufacturer and review them and see if retrofit solution is an option. The tubing might be an issue since dowels are required. If you have a decent map of the tubing, draw it out and forward to the lift manufacturer and ask if they see a reasonable retrofit solution. The mesh and tubing was lifted into the middle of the concrete during the pour or is it on the bottom of the slab? The pink vertical rear bar nubs are for top of slab demarcation?
partsguy5768
Yep I have three lifts. A 4 post and two of the two posts. Yea you can "work" on a 4 post great for oil changes and fast work as getting on the lift is much faster. But I do a lot of car building and the two post is so far superior its not even a contest which one is better in my experience.
D
decrepitdrew
The mess was lifted to the center of the slab.
whateg01
doo dah, kansas, usa
James
How do you drop the subframe out of a car?
partsguy5768
Personally I would just bolt down and go...I have done two posts lifts on new slabs ( I pour 6 inches with rebar 18 on center) and a old slab at our current house that had a small 26 ×36 shop I fully remodeled and now use will use only as my " clean " shop as I have a much larger shop under construction and nearly done. I use all the time lifting heavy rigs. I think most issues with lifts is people loading a rig on improperly vs concrete issues. You have way more concrete going on under that post then the vast vast majority of lits in use. If the rebar is up off the bottom I Personally would bolt down and go. Good luck
ericm
Southern Oregon
The saw cuts are for crack control, so the crack happens there and not somewhere worse. So what happens when the cut is over a 12" thick footer? Does that part crack too? All the way down?
For the OP- the contractor is taking responsibility, right? What do they propose to do?
partsguy5768
Exactly crack control. You put control joints in and some of time on a slab one will still end up with a crack out side control joint. Now what? No lift where you have a crack? If you have a 5 or 6 inch slab with rebar placed properly I'm bolting it down and going personally. In my opinion no " expert" is ever going to say its fine simply because the manufacturer said no... its very hard ( if not impossible) to find in todays saaaaaaaaaaaaftey society someone that will say you will be just fine. Ultimately one will have to decide what one is comfortable with.
Rusted Nut
Northern Arizona
So the expansion joint is about 4" deep, not full depth through the footing? The slab and footing are integral - correct? In that case you could use long epoxy anchors into the footing.
partsguy5768
Rolling air jack and rolling jack tray with jack stands. 2-post is easier but it can be done on a 4 post.
James
Yep.... it can... but I don't and I have both.... it takes a fun job and turns it into work...
D
decrepitdrew
Expansion joint is maybe 3/8 inches deep.
Slab and footing are intact and all together in a monolith pour
D
decrepitdrew
I’ve got 12 inches under this 3/8 or so deep expansion joint. And the footer and slab are all one cohesive pour
