Convert Dewalt Impact Detent Pin to Hog Ring?
mike93lx
Richmond, VA
I recently picked up a DCF899 kit (High Torque 1/2" impact) for a smoking deal, but didn't really think about the socket retention as this is my first impact other than 1/4" drivers.
I had no idea that a detent pin requires using a pick to get the socket off. Not the end of the world as I am just using it around my home garage, infrequently and not for any major projects.
With that said, it's still a PIA. Any ideas on either modifying the pin to make it easier to remove (filing it down a bit?) or if it is easy/possible to swap it over to a hog ring anvil?
PR1Gneon
DOn't need a pick to remove the socket.
Sent from my SAMSUNG-SM-N920A using Tapatalk
gdocktor3
Connecticut
I just checked ereplacementparts.com and they had replacement anvils for the dcf889 for $36.00. That's not the model in question, but if you contact them and ask if they have parts for the dcf899, I'm sure they can help you out. Replacement anvil and a hog ring, you'll be good to go. If you have the courage to swap the anvils on your own that is...
JD.
I ground down the pin to more of a ball which is great!
stercorarius
Eastern Washington
I've been using same one for over a year and never once used a pick to pull the socket like you have to with the Milwaukee. You just have to pull real hard. I prefer it that way because I can't stand sockets falling off like they did when I had the hog ring model. That being said, I completely understand how it might not be your preference. Here is what I have seen a lot of guys do as a cheap and easy fix. They buy the shortest extension they can find and just leave it on there and only swap the socket so they only have to deal with the detent if they need to save an extra inch and pull the extension off.
Sent from my S60 using Tapatalk
BMack37
I have a Milwaukee with pin detent. I took a well used long PH2 bit that was junk, cut it, ground off the sharp edges and keep it in a bit holder attached to the impact wrench. Could probably use whatever bit but it's what I had laying around.
stercorarius
Eastern Washington
Huh maybe they don't put out consistent tools or maybe it's a socket thing. I've seen a handful of Milwaukee detent pin anvils and even owned a compact one and they all required picks, but I've never seen another DeWalt one other than mine that doesn't need a pick so I can't say they all do or don't.
toolman9w
Southern Indiana
Could be different sockets. If they are more square cut hole they may hang up.?
PR1Gneon
X2 I own the dcf899 and never had an issue with the detent pin.
Try with a file and lube.
stercorarius
Eastern Washington
This is probably a large factor. I use Sunex sockets and they all come off with a reasonably high amount of force. Recently replaced my 19 mm with a proto after beating the sunex out of shape on a stubborn u joint. Didn't think about it until I read your comment, but the proto is almost impossible to remove unless you pull on it just right.
PR1Gneon
Do the test and try various brands sockets.
mike93lx
Richmond, VA
The husky socket that i was primarily using had a flat bottom hole and no amount of pulling was getting it off. The retention is great, but i was just surprised at how hard it was to switch sockets.
mike93lx
Richmond, VA
Good idea
ItsNemo
Canada
Pin's ****...and I doubt most of you guys are pulling them off when lined up with the hole in a socket. I usually put the sockets on so the pin isn't through the hole just to make it easy to get them off.
Other thing is you can just leave a super short extension on the drive end locked in and use sockets on that. It does extend the length and decrease torque a bit but could be a cheaper solution.
Handyfarmer
in the high plains of Colorado
I do not put the pin in the side with a hole in the socket, and for 95% of the socket use it is more than enough to keep the socket on,
if I am having trouble put the pin in the hole in the socket, and it will not drop off, such as with an extension, or a u joint/
mike93lx
Richmond, VA
I found that the socket would just fall off if i didn't line the pin up with the hole. Way more annoying than the trouble to remove, imo.
I thought about an extension, but this thing is quite long already. An extension will just make it unwieldy.
American Locomotive
Rhode Island
The only impact I used with a retention pin, had the pin sit so proud that you couldn't even push a socket on without first pushing the pin in. If the pin was lined up on the hole, there is absolutely no way you're pulling the socket off without pushing the pin in.
PR1Gneon
What about trimming the pin spring?
ItsNemo
Canada
Yup, that's exactly my experience too...have to push the pin even to get the socket on.
WittHay
Surrey, BC Canada
DeWalt uses a angled pin detent, makes it easier to get a socket on. Pins on impact extensions or universal joints are usually straight and a bit longer
When its new you cant pull the socket off when its lined up with the hole. I imagine after a lot of use especially if you don't line up the hole, the spring will lose tension and the end of the pin will wear down.
ihateminimumwage
So what would you call the pin detent on the one's that do pull right off?
Defective.:D
Pin detent is made to lock a socket on and use a tool to remove, not work like a ball detent. It's for situations where quick change of sockets isn't needed and if that socket drops, bad things can happen (at height, manufacturing, etc.).
If a hog ring impact isn't holding on to sockets, it's time to stretch the ring open again, replace the hog and o-ring or replace the socket.
OP, hog ring model is DCF899HB, and it looks like the anvil is N103884SV. Seems to average about $30 shipped if you want to make the swap.:thumbup:
mike93lx
Richmond, VA
Defective.:D
Thanks for the part number. That price isn't terrible, but i'll try a file first
catron44
CT
I had the same problem. I soaked the anvil in some oil (can't remember which) and it now works fine as far as I can remove the socket with my hand.
Sent from my SM-G920V using Tapatalk
