Convert IR T30 Vacuum Pump to Compressor?
dirkelstein
St. Louis Missouri
Anybody ever hear of taking an industrial vacuum pump, in this case a Ingersoll-Rand vintage T30 and running it as a compressor? I am thinking less than ideal, since the load on the pistons, rings and valves would all be "backward", no?
<a href="https://picasaweb.google.com/lh/photo/HEGAKTdWHF5RdDbl9gblTKjRlaCM7VOKcd5qBVWo6D0?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-1u_nBz1fT0U/UEadmWakyQI/AAAAAAAABno/bRQjlsmZhow/s400/IR%2520vac.jpg" height="300" width="400" /></a> <a href="https://picasaweb.google.com/lh/photo/0cUbyF-zOzJHynaenAEwY6jRlaCM7VOKcd5qBVWo6D0?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-miTI6c_VQ2c/UEad04PatpI/AAAAAAAABn8/98-MJmBW7VE/s400/ir%2520vac2.jpg" height="300" width="400" /></a>
bsaint
Manchester, CT
For once I am not sure but thats pretty cool. Never seen one of those before. It also looks like its single stage.
D
dirkelstein
St. Louis Missouri
Yes, it's a single stage, twin cylinder, Bore is 4", stroke 2.75". The pump is an IR 244F2, 800 rpm. I think the bore is 4", stroke 2.75". Comes out to ~32cfm at 800 rpm....Not really expecting that, but the math is pretty cool. I am wondering where to look for rebuild kits.
Also found this pic elsewhere online. I think the tank is actually a vacuum tank! Very "backwards".
<a href="https://picasaweb.google.com/lh/photo/tf3rU-yPZiGDa0xzt8oKjqjRlaCM7VOKcd5qBVWo6D0?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-OHP-bd9LCD4/UEaycElApGI/AAAAAAAABoM/BHLtQmmv3qw/s640/VacuumPump.jpg" height="480" width="640" /></a>
rlitman
Long Island
My understanding is that the T30 is an industrial compressor pump. Using it as a vacuum pump would have been running it backwards.
D
dirkelstein
St. Louis Missouri
I am going to call IR tomorrow and ask their tech support folks. Seems there is a "kit" that they sell to convert the vacuum pump to a compressor.
JHag
Well, years later here I am in this situation.
How'd it work out?
nadogail
Coronado, CA
You would have to relocate the check valves, remove the check valve from the intake and install one on the pump exhaust.
kbs2244
could someone conact IR about the "kit" and what it is made up of ?
