There has to be a simple trick to make this connection.
I have 1/2 copper running up the wall to the attic. From the copper pipe I have a 2 foot whip that leaks at the connections.
They are crimped hose connections. Its a lead in hose, whatever that means. It says its rated at 250 PSI and I assume its for this application. However, whenever the compressor fires up the hose ends leak around the crimps where the fittings slide into the crimps.
I have tried a harbor freight version and it was worse.
So what do I use to go from the copper to the tank? Is there a special recommendation, do I need to crimp the hose myself? Should I put some special goop on the connections?
Its not the threads that are leaking, its where the hose slides over the brass end piece and is crimped to the hose.
