Cordless ratchet. Snap on or IR?
SuzukiGS750EZ
Hey guys, at work I use a CTR761A from snap on. I don't like where the battery is because when I go to manually ratchet I can feel the battery flex. I have not had the opportunity to handle the ir r3130 but I'm an ir guy and I'm kind of leaning towards it. Thickness wise, how similar are the heads? Is the IR more fine toothed? My buddy bought a Matco one after I ranted and raved about how much faster I can get things done with a cordless, but it looks like it has a similar battery setup.
Skin
Boston
Post a picture or two and some impressions after you get it. I think only 1 other member has one that has mentioned it, hence the lack of response to your thread.
SuzukiGS750EZ
I will. Specs say it's 20ft lbs more than the snap on one I use. I'm looking for the red boot that most of the tools come with but can't find one.
DodgeMech
yeah, the snappy is a pos...only reason i own one is cuz i got it as part of the 569 bucks worth of free stuff i got from buying a box on the ec plan...and i use the 14.4 volt batteries on my screw gun
SuzukiGS750EZ
My boss said he got one for his brother for xmas and the ratchet was huge. We'll see...
GSteg
Earth
The 12V (R1130) is the same size as the Milwaukee if you're looking for a small one.
The R3130 is a large ratchet. It's large as my 1/2" drive air ratchet (109XP), but longer due to the battery. The body is pretty sturdy too. I was able to apply up to 150 ft-lbs of manual torque without issues.
joejeep92
Kansas
I like my Snap On but I only have it because I got a smoking deal on it...I got it and immediately thought I will never use this. Turns out I use it every single day.
chadster1
Terrell, Texas
The milwaukee m12 is what is in my toolbox. Size was the determining factor for me. The set I ended up with I had to repo twice. After the second time, I figured that since the tools kept finding their way back to me, I had might as well keep them.
SuzukiGS750EZ
Will be posting pics sometime tonight or tomorrow. I just got the boot last Friday and the ratchet today.
SuzukiGS750EZ
225 rpm. 54 ft lbs. 4.4lbs with battery. Very comfortable and balanced in the hand. I like the battery placement better than the snap on one. It's the same head as the 107XPA
SuzukiGS750EZ
It's larger than the snap on one I'm used to using. Also larger than the Matco and Milwaukee. But what I like about it is the battery placement. The head is a bit big but if I'm needing to shove it somewhere like that a 1/4" is more suited. I love the trigger. The only way I see the size being an issue is working in wheel wells close to the ground.
SuzukiGS750EZ
I'm wondering how much manual force you can put on the ratchet. That's my only question. The snap on one feels really cheap when I go to break a bolt free.
Sanctifiedsinner
California
Thanks for all the info guys, I've made up my mind for the r3130
As opposed to snap on's more expensive 14.4v ratchet. Friend almost
Convinced for snap on due to available payment plans if you're
Vouched for.
