Cordless Trimmers
cody1325
Southwest Virginia
Last year, I decided to dip my toes into cordless outdoor power equipment, starting with this little Craftsman which was on sale at the time. A little gutless, but works amazingly well in tight spaces. The reduction in noise, vibration, and especially weight make it much easier to use. Mostly bought it for my grandmother since she didn't have to start it, but I swear, I'm more and more certain I'm making the switch myself. Even with large batteries, it's still lighter than gas equipment. As long as the batteries are charged up, you're good to go.
However, because of the small size, it's really not suited to heavy jobs (a sizeable 3 acre yard and occasional fence line work). I mostly use it in places where the more powerful gas weedwhackers can do damage or are too large to fit (i..e greenhouse).
For comparison, the gas trimmers belonging to myself and my grandmother are both Stihl--FS40C and FS70R. FS40C has a 15 inch swath, 70R 16.5.
The first question I have--should I get something other than the 20v stuff most of the entry level offerings seem to be? Seems even Craftsman has more powerful models, but running on the same 20V batteries. Guessing the 18/20v stuff may be more in tune with what the 40C can do, but not the 70R. For the standard cordless tool platforms, I'm not above selling the Craftsman junk off and buying a different platform. Yet, for the more powerful outdoor power platforms--don't know. Really don't use the hedge trimmer and blower enough--though I could use a new blower since the twenty-year-old Sears Craftsman I have needs a ton of work.
Also, batteries. My stack of Craftsman batteries are 1x 6 amp, 1x 4 amp, and 1x 2 amp. The 6 amp seems to last a decent amount, . So, should I still continue to buy two?. Seems that if I do, for most, 6-8 amp hour batteries cost almost as much as the tool--at least 50%. Most seem to come packed with a 4 amp battery. It seems that high-drain tools have more power on higher amp batteries, but they're costly.
Budget is around $300, plus about 50% of that on top for an extra battery or two. Locally, I have Lowe's (Kobalt, Craftsman, EGO, and maybe Toro?), Stihl (my favorite independent dealer, Deere, Ace), another Stihl dealer (that also sells Toro), and Rural King. Plus probably more than a few outdoor power dealers I don't know about (which may sell more of the Husqvarna lineup).
Harbor Freight. I'm there quite often, and I may wait for coupons since I'm sure I'll enevitably get a 25% off coupon when I renew ITC next month.
Husqvarna 320 iLX. 36V, 16 inch swath, so between the two in performance. $300 with a 4 amp battery, and the additional 8 amp battery is currently $150 on special. But, so far, haven't found a local dealer.
Milwaukee's got a ton of them, and Rural King does sell some of them. Given that even the pro models are 18V, they should be lighter than most others.
I'm really liking this Quik-Lok model, and the brush cutter attachment that is bundled with it should come in handy. $300, but I may add some of the bigger batteries and the pole saw if I decide to order it.
Echo--apparently, we've got an Echo dealer a couple towns over.
Ryobi--little more than an hour for a Home Depot. This one's $230 with a 4.0 AH battery. Like the Milwaukee, it's got a quick-swap shaft that can take other attachmennts. My grandmother should like the weight due to the carbon fiber shaft. Extra 4.0AH battery $100, plus $100 for the brush cutter attachment. Also, I think 2 4.0 AH batteries can handle the whole yard or even a decent amount of brush cutting along fences and the like.
Kobalt 24V with a 14-inch swath (smaller than what I'd like, but it's $130 and sold at my local Lowe's--still a huge upgrade over the little 20V Craftsman.
And Harbor Freight. Cheaper, and I figure if I pay the little bit extra for the two-year warranty, they have to replace it regardless. Also, my ITC renewal is coming up, and I seem to recall that came with a 25% off coupon when I renewed it last year.
The main problem I have is that once you factor in the batteries and chargers, they're slightly more than the competition.
Supposedly, the 80V is comparable to an EGO.
Steve_P
I recently bought the Ego, I think the 1500?, and used it for the first "real" time last nite. I have just over half an acre with something stupid like 800 feet of edging and trimming between the curb, sidewalk and driveway. I trimmed and edged last nite and did everything using only one bar out of five on a 2.5A battery. It's definitely heavier than my Echo bent shaft gas trimmer, so not for most AARP members without the strap/harness, but otherwise it's great.
The Makita and the Ego were the top two per Consumer Reports, with the Ego one point behind, but considerably less expensive.
C
cody1325
Southwest Virginia
Definitely checking out the Ego at Lowe's tomorrow then. Looks like they have some pretty good sales on them as well. Noticed they have one of the 56V models bundled with a blower for $250 at the Lowe's near me. Only problem is that the blower was used so sparingly, I think it's been 10-15 years since I touched the Craftsman we've got--to the point I need to redo the entire fuel system on that 20 year old machine. Thus, a blower isn't of much use.
C
cody1325
Southwest Virginia
I bought a Stihl.
Had it a year, been happy with it so far.
While more expensive, sticking with Stihl would save a lot of hassle. Same warranty, same dealer I go to for pretty much all the gas stuff (save for one beater Poulan Wood Shark I have basically made a test mule to teach myself small engine repair), and I'm pretty impressed with the power my little GTA26 saw has. I assume the full-size stuff running on bigger batteries is better.
Steve_P
I checked and I have the ST1511T. I bought it at my local Ace hardware when it was on sale, but only like 10% off. Shocked that you have no use for a blower; I use my Ego all the time, even to just blow out the garage.
Edit: Project Farm did a cordless trimmer test that you should check out.
C
cody1325
Southwest Virginia
Definitely a use I can see for both the garage and shop--both tend to get a lot of leaves in them if I leave the door open. In the shop, I can see that as being much quicker than sweeping to get rid of trash and such. Also, cordless means no fumes.
Steve_P
I had (and still have) an Echo gas blower for 40 years before the Ego blower. I use the Ego blower at least twice as much, because it's just SO convenient. Blow out the garage, blow much of the water off the car after washing, blow off the porch, blow the tree **** off the driveway near the garage door for when I open it for some fresh air, blow the lint out of the dryer exhaust ducting.... Sure, the gas blower does almost all of that, but the Ego does a two minute job in half the time, and you don't smell like two cycle exhaust when you're done.
The blower was one of those "I should've bought this years earlier" purchases; it's just that good.
SouthernIllinois
This is the one I bought.
I get about 20 minutes out of the AK20 battery which is fine by me. That's about all I want to do at once anyway...lol
After about rolling the zero turn over into the pond, I bought a Stihl push mower to do the path around the pond. It came with a AK30 battery which will also fit the weedwhacker.
Both came from a family owned dealer that my Dad had a lot of history with. His Kubota came from them as well.
RonnieC
Orlando, FL
I’m locked into the Greenworks 80 volt system. My string trimmer is maybe ten years old now. Still very dependable. I saw that Costco is carrying Greenworks if you are a member. Currently on sale $209 for a 3rd generation brushless with 2ah battery and charger. I believe they also carry a trimmer/blower combo.
ATC
VA
I really like my M18. I took it out of the box and was mowing down waist-high grass and 1/2" pine tree saplings.
pbon
I have all Milwaukee, but I do like having just one batttery platform so I can have plenty of batteries and share them, and I already had Milwaukee tools and batteries. Have a couple of the string trimmers and attachments for the quik lok one, a couple of hedge trimmer, single and double hand blowers, backpack blower, chainsaw, and lawnmower.
That said, if I did not care about staying with one battery platform or just wanted the best battery yard tools, I’d buy something else. I think for power intensive yard work a 40, 60 or 80V battery tool would be better.
vavet
Ashland, VA
I was elated when ridgid finally brought some OPE to the US. I have the blower, string trimmer, and hedge trimmer. I was already invested in the battery platform. The gas units they replaced were more powerful, mo doubt about that, but they are so much easier to use. I have a one acre lot in a subdivision.
Grant F
SW PA
I went from a Toro gas trimmer to Ego about a year ago. Have about 2/3 acre. Love it. Can do a quick trim and not smell like exhaust. Works well.
CJM8515
have an older milwaukee, dumped the head for an echo speed feed and use 12ah batteries and more recently forge batteries. Im doing my 1/4 acre (house in the middle) and it does the job good. but Im only really doing the perimeter and the beds. So far no issues at all with battery life.
Beerhippie
Far NE Oregon
I talked the boss into laying out for this one last spring:
Stihl FSA 120. Best call I've made since the Stihl battery walk-behind mower. The trimmer is $399, bare tool, but the mower came with two batteries (and I can't use both tools at once), so I'm set.
I had no idea how tiring the vibration from the ICE Stihl was. I don't recall what model of ICE trimmer we had, but this battery one outcuts it by a mile. The bicycle bars and harness are great--but I have a lot of trimming to do, frequently. The battery lasts longer than it takes for the spare to charge, so I can use it all day.
OccupantRJ
Eastern North Carolina
I inherited an almost new Kobalt 40 volt trimmer 3 years ago, along with a hedge trimmer, and have not used my Stihl gas trimmer since. I had physical limitations using the Stihl before having both knees replaced, and now I don’t even pick it up because I don’t need to. I recently bought a leaf blower to go with it, so now I have three batteries, three chargers, and three tools.
kngelv
Detroit, MI
I think the Ego is the best bang for the buck. Their batteries charge fast and last a long time. They have been doing the cordless yard tool thing longer than most and really have it down.
James
Lou's Garage
Anderson, SC
I have the Ryobi 40V for 5 years and I'm very happy with it. I bought it because of the interchangeable head and I use the hedge trimmer attachment regularly. It's performance is on a par with any of the gas trimmers I've owned previously except the 4 cycle one which was incredibly heavy. It will easily handle my 3/4 lot edging and trimming on one charge. It will take up to a .095 cable.
Lou Manglass
Beerhippie
Far NE Oregon
Makita appears to be a Bump & Feed Trimmer Head, M10 X 1.25 LH thread, which I guess is fairly common.
That may be what the Stihl uses, too--but being LH thread, I can't use my thread gauges on it.
I like having two of the bump-feed string heads so I can just swap a head out when it runs low--much faster than refilling one.
I have a small collection of other heads, ranging from scary to "that really isn't a good idea".
GRN96WS6
SOMD
Milwaukee, I have the weed eater and edger attachments and haven't been let down yet.
Sumboodie
AK
W
I use my blower to clean the interiors of the vehicles and equipment.
When I had a lab I'd blower him to help remove hair. Shop vac too. He passed a couple years ago and I still find his hair.
IndyGarage
Indy
I have a Makita that uses 2 18V batteries. They claimed it was as powerful as a gas machine. I have no complaints. It works great for trimming and the batteries last long enough to do everything in one go.
As far as being as powerful as gas - probably not. I weedeat a large hillside behind my house a couple times a year. I would say the Makita is overmatched for that job. I have a couple of Husqvarna gas weedeaters that I keep for that hillside. But I really only use them for that particular job.
powertrip
Columbus Ohio
I have had a 40 volt Ryobi brushed trimmer for 10 years and it's still going strong. The original battery still holds a charge too. I'd buy another if it died tomorrow. The Ryobi 40 volt system is great especially with deals from Direct tools outlet online. I have the blower, chainsaw and hedge trimmer.
66HertzClone
Long Valley, NJ
I have the EGO PH1400 and a couple of the attachments available for this, it's nice being able to have a trimmer and a pole saw without having to spend the cash needed to have a dedicated tool. I have the STA 1500 trimmer head and have switched it to using a three spoke saw blade instead of the string, my property is infested with vines, and the blade makes it easy for me to cut these out. Because of my disability I use my quad and drive up to these vines and proceed to cut them back using the saw blade. The PSA1000 pole saw has also been useful, I added the EP7500 31 inch long extension to get some added reach, also use that when using the saw blade head. I have purchased an extra 5.0Ah battery and may add another one of these this spring.
