Cornelius 130-R-3500 Compressor
webtools
I just bought this compressor, it was manufacture in 1958, the hours used meter on it says 0.3 looks brand new. My problem is there is no wiring diagram for it. It seems as if the initial power supply is supposed to be DC but the motor tag says 200 volts, 3 phase. I'm lost any ideas anyone? Thanks
Stuart in MN
Minneapolis
I don't see anything on the tag about DC power, but it does say 200 volts three phase Wye connection. It also says something at the bottom of the tag about 400 Hz, which makes sense since the top of the tag mentions aircraft use.
I'm afraid it's an expensive paperweight...I think the only way you can use it at home is if you can somehow adapt a different motor to the compressor.
RECox286
South Joisey (yeah, that is part of the USA)
Cornelius made compressors for use in military aircraft. Does the
data plate reflect that it may have been govt related ?
I once had a small 3 stage compressor that was 24 VDC that I
used to fill scuba tanks. Just throwing in some perhaps useless
info, but most aircraft generators were set for 400 cycle. Some
may have been 3 phase, depending on aircraft type.
Uncle Bob
edit: I googled the brand and model and got some interesting
hits. Suggest you do the same.
G_P
Central CT
3,000 PSI! If you could adapt a single phase motor to it I bet it would sell quckly to scuba divers.
Sent from my C5120 using Tapatalk 2
pp75724
This unit is driven by a 400hz, 3phas, 200v aircraft ac motor, the DC part 27vdc is for drain control use. You can refer to the eBay item Number : 281063791710.
CNGsaves
KS and OK
If you want to keep the thing, you could get a military generator that is 400 Hz to power it.
Lots of 400 Hz generators are sold on www.govliquidation.com
With the two, you'd have a "paper weight" to run your "paper weight" !! :D
Jim Johnstone
Brantford, Ontario
There is a yahoo group for guys that convert those Cornelius and walter kidde military compressors for use filling scuba tanks. What do you plan on doing with a 3000 psi compressor?
