Corrugated metal ceiling outlets.
Soccer918843
Upstate ny
What is the easiest way without running pvc across the ceiling to cut my outlets out in ny new garage ceiling. I do not have the outlets in quit yet just the wire hanging. I still need to wire my outlets up and get the metal up. I have a couple for the openers and a couple for the lights as well as a 240. Thanks
Terry D
St. Louis, MO.
Sounds like you are not wanting any conduit at all, you are wanting the receptacles recessed. If you are planning on putting the boxes up and putting the metal over it, it would be just like a open wall before drywalling. Use plastic nail on boxes and cut the metal out with a jig saw with a metal blade before installing it. You could use a grinder with a thin wheel to do most of it and the jig saw to get the corners. Post some pictures if you can.
https://www.google.com/search?q=cor...-Ap0JHdbVBz0Q9QF6BAgJEEk#imgrc=5vY36j81yGEnSM
acer66
Western North Carolina
Sounds like you are not wanting any conduit at all, you are wanting the receptacles recessed. If you are planning on putting the boxes up and putting the metal over it, it would be just like a open wall before drywalling. Use plastic nail on boxes and cut the metal out with a jig saw with a metal blade. You could use a grinder with a thin wheel to do most of it and the jig saw to get the corners. Post some pictures if you can.
This but surface mounted metal boxes with emt might look pretty cool if the corrugated is also silver.
On the other hand I could also see myself painting the boxes/emt in a if you can not hide it show it way.
like2wheel
On an as needed basis
Yeah, but i think the issue is that he doesn't know yet where the high ribs will be.
I left enough slack to adjust on the fly, but decided better to surface mount the boxes with the wiring behind.
Bert_
NW Iowa
Even if you use Romex behind the metal I still recommended surface mounted metal boxes. Way easier than cutting square holes and usually looks better too.
Terry D
St. Louis, MO.
I agree, im confused on when he said cutting out the ceiling. Surface mount would be easier.
BreeStephany
Oregon
The cleanest way I have seen of mounting receptacles in corrugated is to use a 4-square metal box to bring your wiring in and a flush single gang mud ring. Set the mud ring flush with the back side of the corrugated metal, then cover that with a piece of flat metal that is roughly 10.5" x 8.5" with a hole centered for the interior section of the mud ring. Generally you want to make the hole 3/16" larger in all dimensions around the interior opening of the mud ring. Trim the flat metal with J-metal to cover the corrugations and rivet or screw the J-metal. You will want to have a minimum interior dimension between J-metal of 6.5" x 4.5" to allow for an oversized cover plate or in-use cover.
jabelding
Maine
Here is a picture of mine, I love the look!
