"Mudder F....... Oops... LOL!!" Thanks for the recommendation on the fire resistant drywall. I work on cars and am always doing some kind of metal cutting, grinding or welding. I did not consider the risk with standard drywall.
I am one of those guys that wants to avoid taping but III can do it. I just hate the sanding. You guys that know what you are doing don't have to sand that much. Sadly, I am not that guy!
My electrical is already run through the studs. I do have some plumbing to do for a utility sink, inside water spigots and 2 outside spigots. I was also planning on plumbing pvc airlines. I'm thinking they should be outside the drywall though in case of a leak???
Thanks!
Wade
Yeah, run your airlines on the wall or ceiling for access.
Here are a few tips on taping.
1) I use mesh tape on flat joints. They make a couple of types. White and gray - which is actually for cement board. I use the gray type. It is double tough. It is sticky on one side. Apply it to the joint BEFORE you mud.
2) I use Plus 3 in the pail.
3) Add water to it. I add water till it is like very wet mashed potatoes.
4) It is much, MUCH easier to apply 3 thin coats than one stiff, heavy coat. It took 3 coats over 3 days to do the wall in the photos in my last post. But I sanded out that entire 9x33 wall ONE time - ready for paint in about 45 minutes.
5) between coats take your taping knife and scrape the ridges and bumps off.
And these are the two tools I primarily use - 6" knife and 16" concrete trowel.
The trowel doubles as my hawk - mud holder.
7) Keep adding water to your mud. By the time I get to the 3rd coat it is so drippy I can hardly hold it on my trowel from the bucket to the wall.
8) Some guys use wide T type trowels and do great work.
I used them too but only for soffit work.
