cost questions
cjg454ss
i have a 1500sq ft garage i want to somewhat cool. im going with a 5 ton packaged unit. i believe its 17kw/hr. im in arizona and would like to keep the garage at 90* or so when its 100 out. i have peak $0.21/kw, and off peak $0.05/hw. what would this unit realistly cost me to run? the garage has R19 walls and R38 roof
C
cjg454ss
is that running the entire hour? i know they cycle on and off but man 3.57/hr is steep
jimp
oo
Do you already have the 5 ton unit? Your shop is well insulated and I'll bet the 5 ton unit is way to big.
I did a quick run for Ocala FL. (you did not say where you lived)and it said you needed 2 tons. A lot of internet HVAC web sites have free sizing software (it's not great but it's better than just guessing).
I have a 72X60X14 shop that is very well insulated and 5 tons is to big.(my mistake don't make the same one).
macdabs
You guys make me sick:sad::sad: Talking about A/C as I look outside and see snow on the ground again from last night ! I hope you feel bad about us in the north east!
Mac
RKA
Yes, he just did the math assuming it would run flat out. That unit sounds too big (even if the shop wasnt well insulated which isnt the case) and doing that will cause it to short cycle which means it can't dehumidify ( which you may not care about in AZ). First size it right. How high are the ceilings? And if you're only looking for a 10 degree drop, the usage should be minimal. I would gamble that you would end up somewhere between $.25-.50/hr to maintain temps. It would be a little more the first hour to bring temps down.
