zak77
I was in the Costco near me last weekend and they had a Lennox mini-split by the exit for sale. No mention of the Mr cool so i guess it's regional??
"Modified in the USA"? What makes you say that? While it is certainly possible, I have serious doubts that this is the case. Based on the two I've installed, these units are factory built and packaged, shipped in containers from Shanghai, arrive ready to sell and deliver. They are turn-key, everything packaged together in sealed boxes with substantial packaging. Frankly, the only other international products I've seen packaged like this is the stuff that comes from IKEA.
The only reason I can think of that there would be returns is if there is a serious issue with component failure - which I doubt since millions of these type of units are made and sold all over the world - or from user error on installation. It's not as easy as they make it out to be, and every installation varies a bit due to site conditions, walls, rooms, terrain, etc. And you need a direct-wire box with 115v for the 12K unit, 220/240v for the others. For most people that presents a challenge without hiring an electrician.
Yes, will be interesting to see. I think the only reason more of them aren't sold is that people are just not very DIY savvy these days. Most can't even pickup a hammer or screwdriver, don't change their oil, can't even build a simple wooden project. [shrug]
A recent visit to Home Depot in the afternoon revealed the majority of the customers looked like handyman laborers. I'm sure this chain's success depends on DIY'ers, but I don't think it represents the majority of homeowners. I could well be wrong however.
Is Costco offering these units anywhere?
The DIY units were typical units shipped to the USA and the line set was added in the USA -- they brazed them on. That's why I asked about how the line set is attached. I called and talked to the guy and he told me that they could only do so many with the people they had .... that was a couple years ago. There was also another company that was doing them back in 2014 with a different connector. Someone was also selling them attached -- small 9k 110v units. Had to go through a window
When I called 'mrcool' they said they brought 4000 of them in last year and sold out. I cannot imagine they are doing a modification and re-packing them, or in bulk and packing for resale. But you never know.
My take is the factory is building the assembly and packing, shipping. We have another seller out there with the same units, selling under a different tradename.
I'm sure if you can buy enough of them, or enough containers, you can have your name/brand on them.![]()
yeldogt said:How is the line set attached?
Anyone here know what the warranty is, and how warranty service problems are handled?
With the lower efficiency ratings and the fact you have to run the lineset/condensor, what is the big advantage of going with one of these versus a window/wall AC or two for far less? Seems a 24k window unit (or put it in a wall) runs around $600 and you can do it in even easier.
Not arguing, but I am about to have to cool a larger space and am curious. Conventional split seems to be the way to go yet.
I'm trying to read up if a 36K would cool a 1,500 sq ft insulated metal building without costing a fortune. Anyone know the performance stats on this one as they pertain to cooling efficiency?
Every AC contractor we spoke to and everything we could find said our 45yo asbestos insulated ducts were 30-40% efficiency loss. Plus we couldn't take advantage of any new efficiencies with more modern equipment. They wanted two to five thousand to replace them, however they still work just fine for the old gas furnace we use for about three months a year. It was all lose-lose to me. And only about half of them were accessible without tearing the whole house apart.
So rather than deal with any of that I decided to simply leave all that in place, remove the old AC condenser and lines and go with the newer tech splits. Very happy - and less than a third of the cost the cheapest quote we got for just new AC and furnace using those old inefficient ducts.
I tinted our west-facing Windows yesterday and that makes a huge difference in heat gain. Next weekend forecast is for temps over 100. We'll be sitting pretty.![]()
And this is REALLY where the big win is and why the SEER is so high !But the window unit is full on and full off and nothing in between.
A mini split is way more quiet than a window air unit - the outside condenser of the mini is the same as the indoor window air unit.
The mini indoor air handler is so quiet you cannot hear it - like 29db on low. Amazing.
It's all a question of outcome .. I'm not sure what was wrong with the ducts that they were somehow an efficiency loss -- and where was the asbestos ? 40 years should have been something else.
This whole leaking duct thing is another myth -- they are only a huge problem if they leak to an unconditioned space ... most are easy to fix.
The interesting thing about the new VS equipment is they actually work great with undersized ducts as they zone so well.
You need about TRIPLE that in the ceiling ! With a metal building I hope you got spray foam because those things leak like sieve !I am deep in the A/C buying mode right now. I only plan to run A/C when I am in the shop. It is metal with R9 insulation.
Cut another hole the correct size for the A/C unit you want. For a 3,000 sq ft building you would be better off with 2 unit at opposite ends of the building instead of just one. Or you are going to need some really good fans !The electrical work was just completed and my two windows have outlets wired for window A/C. Turns out the windows are too small for the size units I need.
I'm sure I got sold a bill of goods. Er, well, some tried.
Like I say, our old gas furnace works just fine. We'll be gone in 3-5 anyway, the retirement plans.
And another reason for not wanting to spend $$$. When the money-faucet turns off we can't afford to stay here anyway, will never pay it off. It's so-cal - houses are inflated beyond belief. We'll take our equity and go live where it's much cheaper. LOL
Was not trying to be preachy ...
I have used mini splits with great success -- they are real problem solvers.
So far the only thing I don't like about the mini splits is that they don't shut down completely on their own - you have to turn them off or time them off. Oh well.
That's one of their best features. I have found my outdoor unit completely off when the outdoor temp is cool enough. But having the indoor fan always running on low keeps the space more evenly comfortable. My 1.5-ton Mr. Cool is drawing around 25 watts in that mode. My garage is now more comfortable than my house, even though I keep the set point in the garage higher.So far the only thing I don't like about the mini splits is that they don't shut down completely on their own - you have to turn them off or time them off. Oh well.
Someone PLEASE pm me there Costco login so I can order a mini split. Thanks.
Which unit, which price? Don't forget Costco added shipping charges - Ingrms includes them, so you have to take that into account.
My 24K unit was $1563 from them, shipping included. I don't recall what the costco price was with shipping.
How much difference are you talking? What are they quoting you for a out the door price on which unit?
I purchased an 18k unit from Costco, and finished the install (except for line set cover) a couple days ago.
