Cotter pin removal tool
sgtmac
Wilmington ,nc
Has anyone used one of these. I typically use a pair of side cutter (dikes) to grab the head of the cotter pin and use a hammer to bonk the cotter pin out.
Not sure how robust this removal tool would be?
skipnay
PA
I use this!!!
Pipe
Dikes are what I use too. I usually have them out anyways and its one less specialty tool I need to reach for.
I do have that snap on tool as well. Its for really thick ones to hook the eye, then either grip to pull or hit the "L" with a hammer.
MJD1
I have one , SK I believe. Works good on the small pins used on connecting links. Any other ones, a side cutter works much better.
mailpup
Los Angeles
Is that the intent for that tool? Never seen one before. Every time I get one that's too stuck it seems it is also hidden deep out of sight and reach where only water and rust have easy access.
I believe it's called a seal puller or seal hook. Its original intent would be to pull seals.
Jazz1
Thunder Bay On.
I have a Craftsman cotter pin puller 30 years now. Also good for installing rubber seals around automobile windows.
The snap on puller looks like may be better suited in many instances
mikegt4
sw ohio
I have a Craftsman cotter pin puller like JAZZ1, I am pretty sure that I got it back in the early 1970's. It's useful for a lot of other tasks as well.
dutchgray
Dorset. England.
Fretters
Yes Split pin is what we call them, Cotter pins is the American name.
I use pliers to get them out but I do have one of those pick type tools as well, which does work and is quite useful for other things as well.
unslow1
Illinois
I saw a guy use one of those visegrips with a slide hammer on an uncooperative one. I thought that was a great idea.
T45
Obligatory snap on special tool (photo)
Those bigger handles probably are easier to get leverage with, but the investment depends on how much you need it.
chrisnazzy
Arizona
I have this one and it works well.
B_Bimmer
Eastern Iowa
I am going to be picking up one of those bigger snap on ones. Looks like just the ticket for bigger pins in dirty farm equipment.
WWheeler
Middleofnowhere USA
I usually go at the small / medium ones first with a cotter pin puller or vice grips, especially the latter on larger ones, but if they want to be a real PITA, I go big...
One hit and done.
skipnay
PA
Yes and works great at times!!! Nice to be able to use a hammer on it also!!!
dbabicky
NE Wisconsin
We had them when I was in the Air-Force. Yes, their proper nomenclature was "Cotter-Key Extractor". We called them "The ****'s ****". :bounce: (Not racial, as in the animal, a Raccoon)
Sticks McGee
Trail Creek, IN
We always used them for popping out pinion seals but it is in fact listed in the snap on catalog as cotter pin puller.
2oolhound
BC Canada
Thought I'd post a better photo of the bends and taper on the ends of the snap-on cotter pin pullers. It seems the deeper you get the tip into the loop the more leverage you gain. All those little bends in the tip really work well to give you added leverage. As you progress the tip gets thicker allowing you to really apply a lot of force. It's a tool that just works.
The one on the left is a Mac but I always go for the S-O.
JUNK-MAN
PA
Don't have a pic but I usually use an old snap on radiator pick.
-Brent-
Utah
I have a Las Vegas Tool easy puller, I've removed all the cotter pins from a Model A chassis in minutes (there are lots of pins).
bcradio
New Mexico
I'm not getting the whole diagonal cutter thing? What do you guys do with those? Cut the cotter pin out?
I use pliers to unbend the bent end and then either the same pliers to pull out the pin or my cotter pin puller tool.
ebamba
Hmm, I don't recall calling them by that nick name, just cotter-key extractor. What was your AFS?
