Dr Stan
I'm not getting the whole diagonal cutter thing? What do you guys do with those? Cut the cotter pin out?
I use pliers to unbend the bent end and then either the same pliers to pull out the pin or my cotter pin puller tool.
I'll straighten the bent end with regular pliers or what ever is handy. Then use the dikes to get a real good grip on the cotter pin and use the dike's shape as a lever to pull it out. It may take 2 or 3 different "bites" into the pin as it pulls out. I do not use the cutter to cut off the cotter pin.
