Crack sealer
Joevano
Zimmerman MN
I've got a good 1/2" crack across my floor that really never changes but bothers my wife so I'm tasked with filling it. What should I use for such a large crack that will expand and contract seasonally? Fill it with foam backer first? If so, how deep should I put the foam so I get a good seal with the sealant?
Chris705
The Finger Lakes of NY
Your backer rod wants to be the width of the crack (maybe think about running a grinding wheel along the crack to make a consistent width)...set the rod about 1/4" or so below top slab level. The sealant as zeke describes above is available at HD. using a caulk gun apply the sealant on top of the rod and let it self level. Fill to top of slab (or slightly above) with repeated applications within minutes of each other. Let cure overnight and the next day or so you can cut flush to top of slab with a razor scraper.
Zippercat
TN
If the crack is really deep or has lot of variation in width, I suggest filling the crack with sand to within about 3/4 to 1/2 inch of surface instead of using backer rod. Then use the Sikaflex self leveling as recommended above.
Sikaflex is pretty runny and will drain around the smallest of gaps by the backer rod. Also, if the temperature is under 50 F expect thicker areas of Sikaflex to take a day or more to cure.
lakeroadster
Central Colorado
roc_on_the_rocks
South central Indiana
I had a similar need recently, where the varying width of the crack wasn't suitable for backing rod. Searched a bit on GJ and saw some people using Great Stuff insulating foam sealant. It worked like a charm. Just apply very little rate, you don't want the foam to overgrow too much (although it can be trimmed later). And as Zippercat just said, Silkaflex is vey runny, so if the bottom of the crack isn't sealed well, it'll keep draining expensive caulking.
rburke65
Canfield, Ohio
I just have the width of the saw blade from when they cut my floor after the pour. Rather than stuffing backer rod in the saw kerf, can I not sweep sand into the cut and then use the Sika flex to fill the cut? Seems to me to be faster than stuffing backer rod into the kerf. Did not mean to hijack thread. Thanks.
lakeroadster
Central Colorado
Yes.
Otherwise you'll use copious amounts of sealer.... ask me how I know :lol:
Getting tired of shop vacuuming the control joints after every woodworking project so I bought 3 tubes of Sika Flex Self Leveling Sealant at Lowes.
It'll take another 4 tubes to finish the maintenance bay.
Shea
California
SikaFlex is non paintable and very flexible. Coatings will not adhere well and can crack or fracture under pressure over the joint since the sealant will allow too much flex.
Ch3No2
Ardex Feather Finish if you are going to coat it...excellent results.
