Cracked heater manifold/runner?
boostme
south burbs of CHICAGO
Took apart heater to clean and to convert fittings from LP to Nat gas...and I found I this.
Is it ok to use? Does gas escape from here?
Thanks!
Sent from my SPH-L710 using Tapatalk
dladcock
North Carolina
That will take you out, quick, fast and in a hurry. The problem is you may not be aware it's got you till it's over. How old is the unit, you may could replace the heat exchanger if it's worth saving.
dla
boostme
Not sure how old but its old. Got it used off of Craig's list for 300. Lp output is 120,000 BTU
Damn...well I got screwed..seemed like a nice unit
6768rogues
Western NY
They are generally worth saving until the heat exchanger gives out. Unless it is nearly new and that is a fluke, it is time to put it in the scrap metal pile and buy a new one before someone dies.
Rockhead261
FWIW, a new set of heat exchanger cells are not much more than what you paid, and you've already done the heavy lifting. Depending on the age of the unit you *may* be entitled to a discount on them.
Sent from my SCH-I545 using Tapatalk
CNGsaves
KS and OK
Just get your $300 back from CL seller schmuck who sold you the deathtrap.
Surely that seller knew that crack was there ! :yikes:
boostme
I don't have his number but I'm going to look for it. I should of asked for a Bill of sale.
Its a Dayton 3E243 but can't find much except on Grainger.com that its discontinued
Menards has a nice 75K BTU for $575
What ***** is I had to but a regulator (80) plus another 60 for the conversion kit!!
We'll see..hopefully I can get my money back..but first I will call authorities if they can "help"
HoosierBuddy
Southern Indiana
Agreed that this unit is past it's useful life.
The thing that strikes me is occasionally I'll go into a shop somewhere and see a 30 to 40 year old hanging heater blowing away...and it makes you wonder when the last time anyone inspected the heat exchanger was.
We checked 2 of them at our warehouse that were about that age (and supposedly working fine) and both of them had cracked heat exchangers just like the one in the picture...and had obviously been cracked for some time. My point...you need to check this stuff out occasionally. The seller of that unit probably had no idea the heat exchanger was cracked...because it was never checked. Most aren't. They burn fine so people just assume they must be fine.
Phil
