Well I had a productive weekend. I got a bunch of honey-do's complete and got to assemble the drill press.
I installed the spring incorrectly and need to make the necessary adjustment. It wants to stay fully extended instead of fully retracted. Should be an easy fix.
I still need to clean and install the band at the top. I want to be careful not to be too abrasive with it. What do you use to clean yours?
I have another project to finish this week before starting with the motor. I am pretty sure I will at least need to get new bearings for it. I saw where you ordered from Accurate Bearing previously. Is this still the go-to for you?
Lastly, since I have a little time to order a bearing puller, I have been unable to find one locally so I can look at the size in person. Do you have an online recommendation? I just have no idea where/how to proceed.
Here are some pics for your viewing pleasure!
That is looking really great!
The spring is installed correctly, but you wound it the wrong way. It happens frequently. Before you do anything, take a peek inside to make sure the spring did not go wonky.
When these springs were manufactured, the barrels were wound in a counter-clockwise direction. At rest, the barrel is approximately 4" long and 5/8" diameter. When installed and adjusted, they are tightened counter-clockwise. That will tighten the coils into a slightly smaller diameter and slightly lengthen the spring.
When wound incorrectly clockwise, the coils are enlarged slightly and the spring is shortened slightly. In that case, IMO, there is a greater chance that the coils can twist out of shape at the end where they are outside the pinion shaft.
The spring below is from an earlier 100 or 150 machine. You can see that the end of the spring is wider than the rest. This suggests to me that it was once wound clockwise.
Chances are that you're ok.
There are many options on cleaning, but check this post on how I clean badges, plates and panels.
https://www.garagejournal.com/forum/showthread.php?p=6060823#post6060823
Yes, I use Accurate Bearing. Please be prepared when you call or you may not have a good experience. Better yet, use their website, find the bearings you need and request a quote. You'll get a call back, likely from Lynn. Also, the link below is the VM wiki page with a cross reference of bearings for many Craftsman machines and motors. Not all are listed, but it is a rather extensive list.
http://wiki.vintagemachinery.org/ReplacementBearingListCraftsman.ashx
Most of the bearings I get from AB are either from Taiwan (TPI) or Japan (Nachi). I've always been satisfied with them, but some guys insist on US manufactured bearing. There's no problem with that either.
I can't really recommend a source for pullers. I found every one of mine at estate sales.
I really like my Proto set, though.
Also fyi, your feed stop collar assembly is installed upside-down.
