Craftsman 3/4" ratchet
Zeroek
Indiana
I have a 3/4" ratchet I found in my uncle's garage that he let me have. It has no internals. Does anyone know if they can order a full kit for a ratchet this old? Or could I get lucky and they warranty this thing out.
sha
Texas
Sears will warranty it but i wouldn't unless they could give me a made in USA one that I thought was comparable. That V code is good.
Some Sears will give you a rebuild kit if they can, if not, you could ask them to rebuild it while you're in the store so you can get it back.
kunkernator
US of A
I believe that sears normally carries the rebuild kits for those, instead of warranting the whole ratchet. If so, they should give it to you for free.
Z
Zeroek
Indiana
Yeah I figured they wouldn't give me another USA made one. Would be sweet if they could just put a gear set in it.
zkling
Seeing as how their 3/4" demand is very low compared to the other 3 smaller sizes; your chances are good of finding older USA components on the shelf. My local sears has a heavy coating of dust on the 3/4 drive stuff. It hardly moves.
The thing is, you are missing the key components, cover plate included. Not sure how they will go about a warranty on that.
balane
70Swinger440
Lehigh Valley, Pa.
You got the ratchet for free? I'd bite the bullet, and just buy a rebuild kit if you can't get one from Sears. You're still dollars ahead. I have a spare rebuild kit in my box for mine, just in case.
oldldh
Fairhope, AL
Get yourself a couple of rebuild kits...
Keep one as a spare...
And you AND your descendants will be covered for a couple of eons...
Z
Zeroek
Indiana
Right on. I'll probably just rebuild it myself if they won't rebuild it under warranty. Rather have a USA made one to be honest. And like you guys said I got it for free so buying new internals wouldn't be so bad. I like how it says Forged in USA.
Fedwrench
Valley of the sun
My sears is funny about warranting any ratchet with missing components so funny, that they won't do it. Broken, no problem, missing anything, no warranty. :dunno:
Don't forget that you can also look for a repair kit under the older NAPA/KD/and Allen brands. Did you check Cripe?
It's the same ratchet across several brands aside from the handle shape.
Richard Cranium
central Washington
A rebuild kit will do you now good with out the plate and two screws to hold the plate on. Go to your sears and see what they will do for you. Most likely they will still have usa made ones in stock, not a real fast mover. I not sure if the new ones have the quick release button.
Fedwrench
Valley of the sun
Says the rebuild kit is 43449 for my 3/4" ratchet. Cripes has a gearwrench kit. Ratchet Repair Kit 81499. Taiwan kit but it's way cheaper. And I know K-D and Gearwrench have something to do with one another. http://www.ebay.com/itm/Gearwrench-...156?pt=LH_DefaultDomain_0&hash=item3a6ab4aa5c
I think the Gearwrench repair kit is for their 3/4 inch ratchet head that takes a screw in handle. I don't think it will fit the US made older ratchet.
Gearwrench debuted under the KD brand and to this day are marketed under KD part numbers even though the KD brand is long gone.:sad:
You need older US made parts. I am shocked and amazed to see craftsman repair kits that cost a penny, 15 or so years ago list for $45 on ebay today. :wtf:
Z
Zeroek
Indiana
Got set up today. The 3 guys working in there were cool and had 1 in there that was refurbished USA made but it was a newer number than mine. I didn't push my luck and just took it lol. The hard handle screwdrivers must still be USA made since I've gotten a few warrantied that I ended up getting US ones. Then had a 6" quarter inch extension that was almost bent in a U shape they swapped me out for a new one too. No clue how it got like that but they took it.
Z
Zeroek
Indiana
Yeah I ended up comparing the tooth count on both kits. Was hoping they were the same because of the price difference. If they wouldn't had took care of me I'd bought that $45 kit on ebay. Woulda been worth it for a nice ratchet.
ARFLY
NW Arkansas
That is cool they got you taken care of. So what kind of jobs are you all doing with a 3/4" ratchet? I haven't had a job that required a 3/4", but I am not a professional wrencher either.
stage20
pcola FL
i just bought a rebuild kit for my KD. its the same as allen and napa as mentioned. it came with backing plate and new screws.
http://www.toolsource.com/repair-renewal-741122-ratchet-p-94021.html
i cannot confirm if yours is the same as my KD, but they look similar.
Gear Wolf
From my experience, I've usually had to talk to a manager or a tool "specialist" to special order particular rebuild kits. I've had reasonable luck with doing that to date.
While most new C-Man stuff is Chinese, quite a few stores still carry USA rebuild kits. They will trade with one another to get customers what they need. You just have to wait a week or two.
Z
Zeroek
Indiana
More than likely won't use it at work with having Air power and working on tiny Hondas. I'd say I'd use it for stuff like Axle nuts at home. Even though I'll probably keep it at work since it looks good in my box lol.
cliftonbros89
Missouri
Both Sears locations nearest me will not give you a rebuild kit, nor will they rebuild it for you. However, the do have rebuilt ratchets on hand to warranty. I just had a 3/4" one replaced myself last year. The handle itself was still the same USA made model I had before. As to where the rebuild kit inside it they used was made I have no clue. I didn't bother to ask because I doubt the person assisting me would've known either
Gear Wolf
Really? That is a little weird. Shoot I don't even have to get assertive/insistent to have the stores in my area special order the parts should they not have them. I've been told on multiple occasions that the Sears SKU system rings up each kit as $0.01.
About a month ago I a little distraught about finding out that C-Man hand tools haven't been made in the USA since 2012. I called one of the local Sears owners and was given 2 ratchet repair kits for just about every ratchet set/size through QR through the current USA Premium Ratchet. I wound up with a few breaker bar repair kits and unfortunately a few Chicom-Man ratchets repair kits too.
This reminds me of that story I read on the Consumerist: http://consumerist.com/2009/03/13/craftsmans-lifetime-warranty-depends-on-tool-associates-mood/
Seems like warranty and access to kits is based on the preference of the store owner/manager, which isn't right.
cliftonbros89
Missouri
Yeah. It's kind of annoying. Neither store seems to really care. The employees are there just to collect a paycheck and that's it. (Also why I've been waiting on 2 flat head tip sockets to be replaced for about a year and a half now)
I figure I'm lucky they even have refurbished ones to swap out with the busted ratchets. One of the stores even refuses to carry the premium grade ratchets in stores.
Gear Wolf
Agreed. Craftsman really has gone down hill. I have since moved on to Wright, Cornwell, and Snap On.
There is a video series that I created on YouTube describing just that fact. Check: Craftsman USA vs China. To my knowledge, the last USA Craftsman tools were of the Industrial line, which was discontinued since 2012.
