Craftsman 6” Vice - Replacement Jaw Plate?
Jeffncs
I have an older (20yo?) Craftsman 6” vice with a broken jaw plate. I may be using the incorrect term - referring to the metal fastened to the actual vice that’s removable.
I’m about to start another car project and am tired of nursing the broken piece to work. Does anyone make replacements?
I’ll get pics later for ease of understanding.
Thanks!
J
Jeffncs
Pics…
BE7E90E6-A948-47FD-96CB-82B397548556.jpeg04D280D6-E18D-4885-AE52-42F1C27CF717.jpeg5348BAFA-2E1A-48E5-ACEF-03DA323DD249.jpeg
Edit to add - I have only found one replacement option for $60. That seems really expensive considering other options are $20, but unknown compatibilit.
captaindiode
NC
Look at these:
According to ereplacement parts the jaw faces are obsolete, but the part number is 87005S41 which matches above. Length is 6.5 inches. The model number of the vise is slightly different but jaws look similar.
J
Jeffncs
Look at these:
Thank you!! I didn’t think to cross-reference the p/n. I was focused on the vise model #.
$20 vs $60 is a no-brainer! I’ll order a set right away!
larry_g
oregon
Looking at your close up picture I'd recommend that when you get your new jaws that you take a file to the casting to make sure that it is flat and has good contact between the jaw and the body. You may have a bow in the seat that puts additional stress on the jaw. Your new jaws may also need a bit of straightening. I'd also be tempted to cut the jaws shorter so that they are fully supported and not hanging out like they are now.
lg
no neat sig line
NUTTSGT
Northern Central Ohio
If you order them, post up what you get and how they work out. I'm needing a new one myself and considered just making one out of piece of aluminum.
bubinga
lg
no neat sig line
Larry will tell you right!
