I have the Craftsman one. It works fine!
Go with a vice grip I have used several types of chisel holders snap on, armstrong etc eventually the threads or the tension nut give out. Handles split or they do not grab the chisel tightly once the tip gets worn.
Go with a vice grip I have used several types of chisel holders snap on, armstrong etc eventually the threads or the tension nut give out. Handles split or they do not grab the chisel tightly once the tip gets worn. If you add in the time to change between chisel's IE using a couple of different types on one job the time to change will annoy you after a while. Vice grips WR style work well just make sure you keep the chisels dressed if the grips slide a little.
Cypher
Assuming you want to use this trick, what does experience say about using the 5 incher? Too small? or GTG?
