Craftsman Drill Press
F
FrankLee
seMI, 48317
101.07301 Atlas Craftsman Metal Lathe, 103.23440 24" Craftsman Jig Saw
I just got home with these two machines...
a 101.07301 Atlas Craftsman metal lathe and...
a 103.23440 24" Craftsman jig saw.
4/14/2021
Today, I freed, removed, dismantled, cleaned and reassembled the tail stock.
Likewise with the Watson MFG. Co. Craftsman 111.21380 4", 4-jaw chuck, patent US1977658A.
There's a bit of pitting around the mount edge, but it's fully functional.
I also got the compound rest assembly moving fairly well.
I made an initial attempt to remove the Atlas 5635 3-jaw chuck, but did not want to force and break something. I did discover that the large gear adjacent to the cone pulley slid over to the right. I don't believe there should be a space between them. This causes the indexing pin to drag on the holes in the edge of the gear.
I'm hoping to remove the collar on the far left of the shaft, loosen all the set screws to the right and remove the shaft with chuck.
4/15/2021
This morning, I started on the countershaft assembly.
Dismantling this assembly was a *****! There are six set screws along the shaft and only two flats. The other four set screws were tightened on the circumference of the shaft and they all created burrs. They cone pulley was particularly difficult to remove. Fortunately, nothing broke.
I also removed the carriage and compound rest assemblies from the lathe bed...
... and the tool post from the compound rest assembly.
The tool post set screw was slightly bent and badly mushroomed. I had to file around the end of the screw before it would back out.
4/17/2021
It's been a very busy few days. I got everything dismantled and cleaned except the carriage and compound rest assemblies. Several assemblies are back together.
The head stock spindle was another ***** to get apart and out. I still could not get the chuck off the spindle, but luckily, the spindle removed from the right side with the chuck still attached.
There are a lot of parts to this lathe and the many photos I took helped tremendously during reassembly.
I finally got the chuck off the spindle after putting it in the freezer for several hours. The Atlas auto-centering, 3-jaw chuck is a rather simple device with some very complex machining.
4/18/2021
This morning, I soaked the Atlas chuck parts in citric acid, cleaned it up, lubed and assembled it. So nice!
I also cleaned this Jacobs 6A I'll use for the tail stock.
So, as I said earlier, the spindle was very difficult to remove. The large spindle gear on the right was very tight on the spindle and I had to hammer out the spindle while blocking the hub of the gear to the head casting to prevent breakage.
Once I got the spindle cleaned up, I tried to test fit the spindle gear, but it would not slip back onto the spindle. I ended up honing the gear bore just a bit.
4/20/2021
Yesterday, I cleaned the bed ways, taped them and cleaned the larger cast iron pieces with Grez-Off outdoors.
Before:
After:
This morning, I started assembly.
The badges were cleaned and reattached with machine screws.
I'm starting to ponder how I'm going to arrange the motor and countershaft assembly using the 27", 29" and 48" belts that I already have.
4/21/2021
This morning, I completed assembling the head stock. Everything turns pretty good.
This afternoon, I started dismantling and cleaning the carriage and cross slide.
4/22/2021
This morning, I finished cleaning and assembling the carriage and cross slide assembly. I also got it and the tailstock on the bed.
Everything moves so nicely! When I got it home, every single gear was seized on it's bushing. The lead screw was seized in both collars. The compound rest would barely move. The tail stock ram would barely move.
4/24/2021
I cleaned up the jig saw today. It's a nice machine!
subroc
Dover, NH
The lathe looks complete other than the hand wheel handle on the tail stock. Get any other stuff with the lathe?
F
FrankLee
seMI, 48317
No that was it. But for the price, I thought I did pretty good.
These were the seller's deceased father's machines at his mother's house. They haven't been used in a long time. The seller will look for more bits and pieces and let me know.
454ragtop
Carver, MA
Frank, looks like you're missing the countershaft/motor mount assembly. Seller may not realize it even goes to the lathe.
F
FrankLee
seMI, 48317
I got it. It's partially visible on the far left in the seller's photo. It was attached to the lathe with a very shabby v-belt. I need to figure out how to remove the shafts to replace the belt... or find a narrow link belt.
row.inc
St Louis, MO
I got this Companion back together to test before I put more into it. It runs fine and the shaft seems to run straight but the chuck itself has wobble. How can I remove this chuck from the threaded shaft without damaging other things?
F
FrankLee
seMI, 48317
Chuck the short arm of a large allen wrench in the chuck and use the long arm as a lever to unscrew the chuck. If the v-belt is still installed, squeeze the sides of the belts together to hold the spindle tight.
row.inc
St Louis, MO
Thanks, it’s off. It wasn’t on very deep. When I try this chuck on my 80, it screws right on. When I cleaned the threads on the Companion and tried putting it or another 1/2-20 chuck on it, it stuck at about 1/4” on. I didn’t want to force them further. Do you know if the Companion shaft has a different threading? I don’t see any problems on the shaft threads. I can go get a fine and coarse nut to see if it goes on ok (don’t have any 1/2” size). Thoughts?
row.inc
St Louis, MO
The threads on the Companion shaft look closer (more per inch) (39 in the 1 5/8” exposed) than what’s on the 80 (33 in the 1 5/8”).
F
FrankLee
seMI, 48317
Hmmm. 39 / 1.625 = 24 tpi. That's the same tpi as some grinder shafts.
I believe the original chuck was keyless in the same style as the old hand braces.
row.inc
St Louis, MO
Re: The Classic Craftsman 100/150 Drill Press
Thanks FrankLee and Cruzan80, I've started scouring FB Marketplace looking at old braces. Most around here seem to have only two jaws but there is a Stanley ratcheting one which might be promising.
Cruzan80 let me know if you have the chuck (and cost) in case I can't locate one here reasonably?
I have a floor 150 and picked up this Companion and the 80 so I'd have a benchtop option figuring whichever rehabs best stays and the other will be sold in better condition than it was.
The Companion was cleaner and seemed complete even with spindle cover. The 80's paint is more chipped and was missing the chuck. So I picked the Companion rehab first. Now that I find the chuck on the Companion is wrong and actually fits the 80, I guess I'll have to switch and work on the 80...
I'm sure you will appreciate the slippery slope that while Companion parts were soaking, a fellow here gave me his Enco 126-2172 floor model since it needed work (table wouldn't raise/lower) and he needed more space. Turns out it just needed minor cleaning and the table crank handle spindle adjusted. I'm thinking that someone forgot to unlock the table prior to trying to force the crank to work.
Then there is the 100 which preceded the 80 and Companion but is missing the knob for the quill tensioning spring. I've set it far to the side for now. If I find the knob great, otherwise this winter I'll try a hard rubber stopper with metal fingers drilled through to capture the spring tang.
Mill Valley, CA
I acquired a craftsman 103.0305 drill press about a year ago, and it is a rusted hulk. I have been slowly rebuilding it and found key parts are missing or damaged. I'm stuck on the quill disassembly since I have just ordered the chuck wedge removal tools. I also discovered the coil return spring is missing. Does anyone have photos that show how it is supposed to look for assembly? Does anyone know the specs on the spring I will need and where to source it? I'm also trying to find the mohawk cover!
F
FrankLee
seMI, 48317
Welcome TE!
I've had a couple of those early King-Seeley machines, but can't help on the spring specs.
Search "mohawk" in ebay active and sold listings for photos of the spring housing. I do have a quill assembly if you have any specific questions.
You can also search GJ for 103.0303 and 103.0304. There have been several mohawk refurbs highlighted here.
F
FrankLee
seMI, 48317
Very nice eye! Very hard to find belt cover ! Cant wait to see what you do with it.
My plan is to
  • take the cover to a nearby Sherwin-Williams to have it scanned for a color match
  • strip off all the paint
  • patch the cut-out
  • repaint
I was able to chip off some of the yellow paint, but much of it is not easily coming off. I cut a patch from a fubar band-saw case, but I'm still not sure how I'm going to attach it. I'd like to have it tack welded, but I will likely try to use Devcon epoxy... not sure yet.
I put this and everything else on the back burner though, while I work on the metal lathe.
11b30b4
GA
Frank, that cover is nice. Although I do prefer the open top look. However, that Metal Lathe is the bomb! I believe you will find it extremely useful once you get it running. I am glad you are keeping.
SenorDrill
TX
Hello all,
I just purchased a 113.213780 from a guy and am very grateful to have found this forum/thread. The amount of information here is fantastic! I'm currently looking at rebuilding my drill press to functional/clean status, but don't think I'll be taking it down all the way (it's in pretty good condition).
I have 2 quick questions:
- anyone know how I can find the belt cover assembly for one of these? It's a "late 150" and had the cover that just pops up, but mine was totally missing.
- similarly, anyone know where I can get the accessory rear table? I have the chain-lift accessory but would also like a table that can potentially rotate.
Thanks for reading and to all that have contributed!
JZiggy
Atlanta
FrankLee, I had one of those 24" Craftsman jigsaws come through my shop a few years ago. It was just way too enormous for me to store or do anything with but it was very cool!
F
FrankLee
seMI, 48317
Hello all,
Welcome!
I have a cover from my dp#94, a 113.213710.
It has holes worn in both sides from the motor pulley, but it's not terrible.
The aux table will likely be on ebay sometime, but pricey.
F
FrankLee
seMI, 48317
It IS gigantic! Heavier than I can carry myself. The nice thing is that there's no oil reservoir in this model.
JoCoSawdust
Eastern NC
As I previously mentioned, I'm refurbishing an early 100 DP. I'm going with a charcoal gray as the lighter battleship gray of the early 100's doesn't float my boat. I've been spending a lot of time on this thread to learn. Many thanks to Frank and all who have contributed knowledge here! I ran across some questions about dealing with a FUBAR data plate. Apologies if this horse has already been beaten but I haven't made it through the entire thread just yet. The data plate on the machine I'm currently working on was toast. My solution was to take it down to bare metal and apply a decal that's available for printing from the Vintage Machinery website. After applying the waterslide decal, I coated with gloss clear. Not perfect but sure looks a lot better than what I started with.
Hoorn
Glendora, CA
Just picked this up today. Surprised to see original Craftsman belts with what looks like Long C logo.
F
FrankLee
seMI, 48317
I like the decal solution. The repop badges are nice, but there's nothing like that original raised model number.
Hoorn
Glendora, CA
Nice acquisition Hoorn. What are you going to mount that baby on?
JoCo, I've got a 150 that I will give it a shot on. Got this from a good buddy for a ridiculously low price, all but free, so I had to get it. I've been looking for an MSA pulley as they seem more reliable and not as temperamental, but for this price, I had to buy it.
Smokeshow69
Ugg, a varislow under $100 is a major you ****! Nice work.:beer:
JoCoSawdust
Eastern NC
Well that's going to be an accessorized masterpiece with the Variety-Slo AND table lift. I'm jealous!! Congrats on the score.
Hoorn
Glendora, CA
Thank you JoCo,
Remarkably, I just missed out on another table lift earlier this week. A buddy of mine who should be posting his find very soon on this thread beat me to it.
Yes these deals still exist out there, the owner wanted $50 for this amazing Atlas/Craftsman DP with that table lift.
I had been scratching my head for months wondering how Frank runs across all these accessory laden DPs seemingly all the time, and lately the pickings here in So Cal havent been bad.
JoCoSawdust
Eastern NC
Thank you JoCo,
That was a heck of deal for somebody. Alien head+table lift+Heritage badged Atlas. I missed out on a floor model Atlas with slow speed pulley and table lift for 75 a while back. I was out of town and the seller wouldn't hold it for me even after I upped the ante a bit.
