Craftsman Drill Press
F
FrankLee
seMI, 48317
My drill press had a 11 56 stamped motor and it (motor) was power bronze, along with the press.
Im wondering if they did changes in the middle of the year.
Absolutely.
IIRC, those date ranges I used were from memory... not always the most reliable source of accurate info. Catalogs sometimes listed machine colors, but I believe they are the best info available.
Bro,
What is the date code on the motor plate? I can't make it out.
Frank, Cruz,
Have you guys seen motor bands that were painted bronze like this one? I've only seen the ones with the turned (sublimated?) stripes.
Yes, very recently.
https://www.garagejournal.com/forum/showthread.php?p=8838605
There were fewer and fewer references to gray enamel machines in catalogs leading up to '58. I have no proof, but it's my belief that Power Bronze first appeared on machines in stores in 1956.
The first reference to Power Bronze paint was in the '59-'60 catalog for the 10" table saw. The last reference that I found was in the 1963 catalog for the belt driven grinders, shaper and 10" table saw
The paint color was not listed for all machines, so its difficult to pinpoint when Power Bronze was used on each machine.
lafester
Northern CO
Can't argue with that... the table must have been damaged when these were still available from Sears. Since there is no evidence of tipping I suppose a head crash could have been the cause.
It is strange that if the dark grey was only 2 years why the bronze is harder to find.
Here are the drill press colors used throughout the 100/150 series and their approximate years:
  • 1946-1956: light gray
  • 1957-1963: ​power bronze
  • 1964-1966: dark gray
Light gray and dark gray are not chronologically adjacent, so I don't think your machine is a crossover/transitional machine. IMO, that table was replaced.
Also, if the 1954 motor is original to the machine, the original table would have been a tilting table.
So the next rhetorical question is whether the replaced table and the cracked head casting are related to some traumatic event. Did this machine fall over and break the table and head?
The issue I see with the cracked column support is that more stress is being applied around and splaying open that support ring. The weakest/thinnest part of that ring is now at the front, 180 degrees from the crack.
F
FrankLee
seMI, 48317
Per my quote in my last post, those date ranges were for Power Bronze in general, not just drill presses.
Out of curiosity, what is the casting number on your table... 103 (K-S), or 113 (EEC)?
zeven7
CA
Re: Table Lift, DP#15
Sure! Let us know what you need and we can help out.
Thank you Frank! My drafting skills are very rusty (had a class in middle school in 1985,) so pardon the crude drawings. I've also been playing around in CAD and mocked up the lower collar. If you can help me get dimensions for the call outs on the reference drawings I'm attaching, it would go a long way in helping me drafting up the 3d models. I'll happily make the 3d models available once complete to the forum for those interested in having them. It's too bad I didn't catch forum member Hoorn before his rebuild. I may have enticed him to see if he would've let me have his parts molded as originals for reproduction castings. I may reach out to him as well to see if he'd let me come by and look at his lift as he's about a 30 minute drive away.
Best Regards and look forward to hearing back. If it's too much work to pull the dimensions, please don't feel obligated as I know this can be tedious.
-Jesse
Corona
Hoorn
Glendora, CA
Pardon the make-shift work area, still setting up shop but needed to knock out a few projects this weekend, but figured I would show the old beater off. Snagged it a couple weeks ago - they were asking $35 but haggled them down to $20 since "it's so old and probably not working very well these days." Didn't even have to clean it! :D
That DP has been SO well maintained. Did the Palmgren come with it? And that's an early 100 too, great score.
lafester
Northern CO
Table is a 113. I was going to flip this one but now I think she will be parted out. Everything on it looks barely used.
PDX
Benton Harbor, MI
It's actually Frank's #98 (the post is pretty much entirely ficticious, dripping with jealousy of people who do actually run in to deals like that). Doesn't seem to have had too terribly hard of a life before he got it though.
Vise was worked in along with it - didn't see any manufacturer's markings on it other than country of origin; is this for sure a Palmgren?
F
FrankLee
seMI, 48317
It is a Craftsman branded vise perhaps manufactured by Palmgren. The Craftsman label was gone when I got it with DP#31. However, there is casting number 2754 on the base under the pivot pin. That is the Sears catalog number from the 1969 catalog and others.
https://www.garagejournal.com/forum/showthread.php?p=6609861
y'sguy
Tulsa, Oklahoma
Thank you Frank! My drafting skills are very rusty (had a class in middle school in 1985,) so pardon the crude drawings. I've also been playing around in CAD and mocked up the lower collar. If you can help me get dimensions for the call outs on the reference drawings I'm attaching, it would go a long way in helping me drafting up the 3d models. I'll happily make the 3d models available once complete to the forum for those interested in having them. -Jesse
Corona
This looks like you are on the right path! I would be interested in one of these for my setup if it can be done affordably. I have wondered if a sears table saw from near the era might be salvaged for the trunion rods and mechanisms to add to building some kind of a table lift. So far I only have my own saw for reference and haven't been able to look into it as yet.
F
FrankLee
seMI, 48317
I've also been wondering about adapting the RAS raising mechanisms... the saws with the crank in front under the tables. There are tons of RAS saws for sale cheap.
zeven7
CA
I've also thought of a few workarounds (everything from cannibalizing a drill press table to using a leadscrew from a metal lathe.)
I'll certainly keep the forum up to date on progress.
-Jesse
y'sguy
Tulsa, Oklahoma
Actually Frank, I should use your method of a counter balance system and call it good. I'm only trying too hard to keep it in the original equipment category and that is not really necessary for me for the cost.
Your solution will work for me, I just need to get on with it. Funny, in the past I used to sash weights around in my stash but alas no more. I'll come up with something for a ghetto counterweight!
:beer:
the RAS lift mechanism I kept for a long time simply didn't have enough lift for ANY project I thought of. It was from a typical 10" Craftsman (the recall models)
y'sguy
Tulsa, Oklahoma
Are you guys using RAS as in Radial Arm Saw? or something I am missing? When I spoke of a salvage saw to use I intended to mean Table Saw. Not that it matters too much. Just wanted try to keep up with you whippersnappers and your lingo! haha
Please continue.
F
FrankLee
seMI, 48317
Please continue.
Yes, radial arm saw...
or sometimes radio alarm saw if you're on craigslist. :lol_hitti
Now thinking about the RAS lift gears, if you lost most of the post, and were able to get a longer screw movement..
Not sure what Gearing advantage is built in those, but if its lifting a RAS, head it should be enough. you would have to do some fabrication for mounting, and coupling in a collar to lift the table. Hmm, I think that piece has been gone some years now...
11b30b4
GA
row.inc, I have been failing at doing anything other than vises currently. I have never gotten around to playing with the spring but I will try to get some time with it this weekend. I will post what I learn once I get some time with it.
subroc
Dover, NH
Frank
I just checked the link to Metro Restyling for machine turned vinyl. The link is dead. I did a search of their site to no result as well. Either they no longer have or carry the product or...
Anyway, have you or anyone that follows this thread found a suitable alternative? Or, am I on my own winging it with whatever I find that looks good on the web?
F
FrankLee
seMI, 48317
Frank
Hmmm. Yeah, their website has changed. They are only a few miles from me, so I'll check them out next week.
Here's a seller on ebay that looks reasonably priced.
https://www.ebay.com/itm/303588272802
subroc
Dover, NH
Thanks
I ordered some of it.
Have you had vinyl decals made as, say, replacements for a Craftsman King-Seeley plate or a crown top or the 150 identifier? Anything like that?
F
FrankLee
seMI, 48317
Re: The Classic Craftsman 100/150 Drill Press
I found this crack on the lower part of the head today. I don't think this is a big deal but wanted to run it by everyone here first.
I saw another issue with a cracked head casting on owwm, so I thought I'd study this a bit more.
Earlier, I thought a mending plate might work well, but after looking at a couple of my castings, the two halves of the head casting are rarely even with each other. One side is usually higher than the other. I think a plate attached to the column cross member could possibly twist and prevent the crack from drawing together.
Here's what I came up with... a piece of 1/4-20 threaded rod and two nuts. I drilled 3/8" from the rear plane and 1-1/8" from the bottom plane. A 5/16" threaded rod would also work.
It's not an elegant solution, but it should be effective.
sheltonfilms
Hmmmmm. If you didn’t like the nuts sticking out, I’m wondering how a turnbuckle inside would do with the rod ends of the turnbuckle threaded into tapped holes in the head casing. Then they could be put flush in the hole.
One con is one hole would have to be reverse threaded.
JoCoSawdust
Eastern NC
I'm throwing out a life line....
I just started refurbishing an early Craftsman 100 DP. This thread, along with 11B's separate thread is infinitely helpful, thanks to all who contribute to them.
The motor is dated 1947 and has this contraption on it. It looks to me like some kind of harmonic balancer but I'm just guessing. My issue is how to get the damned thing off the motor shaft. There's two holes that look like set screw holes. One is threaded, the other isn't and there's nothing in either hole. The threaded hole is high on the system, much to far away from the shaft to reach it anyhow.
The only thing I've gotten to move so far is the device shown being pulled out. It's spring loaded. Let go and it snaps back against the hub.
Wether I reinstall this thing on the motor later on or not, I'd prefer not damaging this oddball in removing it. Any insight would be greatly appreciated. Thanks.
Scott
subroc
Dover, NH
Can you leave the assembly together? Is there a set screw somewhere on the pulleys or between the pulley flanges? Could be all that is holding it on.
454ragtop
Carver, MA
JoCo, I suspect that is a planetary speed reducer. With that spring loaded key in one position it turns at normal motor driven speed, flip it to the other position, it engages a set of planetary gears to slow it down. I have something similar stashed in a drawer here somewhere.
JoCoSawdust
Eastern NC
I found the words "The Pull Gear Company" on it and did some digging. VM has a publication on the device which is designed to reduce the speed of small drill presses. Glad I did crack this thing open as it's full of gears. I'll read the catalog tonight and see if I can go to bed smarter than I woke up.
I've hunted for a set screw with no luck. Hopefully the catalog can give me a clue. Interesting piece.
Good possibility 454 I was thinking possibly a centrifugal clutch kicks in when up close to speed so its not bogged down trying to pull a heavy weight
JoCoSawdust
Eastern NC
Right you are 454, thanks. It does install with a set screw I'll keep reading and figure this thing out. I see where the set screw goes but there isn't anything threaded in there and the device won't budge. This particular model supposedly produces a 7:1 speed reduction.
Outlaw. Seems you can set that spring loaded key in one position and operated at normal speed, with the key pulled out and rotated 90 degrees, the reduction kicks in.
Link to the manual:
http://www.vintagemachinery.org/pubs/10489/15139.pdf
JoCoSawdust
Eastern NC
Victory is mine. After becoming 100 percent certain there was no set screw holding it on, I used every chuck wedge I own to get it as far off the motor shaft as I could then resorted to a wooden dowel and light taps with a dead blow. The manual states that it had a 3/4" mounting bore, thus requiring a reducer for smaller shafts. Turns out there was a bearing placed in the mounting bore and the device was then pressed on. Anyhow..it's off.
I did try the sucker out on the bench before going to battle with it. The top hub has a threaded hole in it. For speed reduction, you pull out that spring loaded device and rotate it 90 degrees. A rod is threaded into the upper hub then braced against the column of the DP. It actually works albeit noisy as hell, probably from not being oiled for a few decades. I only ran it for a few seconds.
The motor had a bit of vibration in it with this mounted. I chalked it up to bearings which I already planned on replacing. Once this thing was removed, the motor runs smooth as butter.
Indexmill, other than not putting this thing back on this motor, I'm not really sure what I'll do with it. Let me get through the refurb on this machine as it's a very, very late birthday present and I'll make a decision. Where about are you? I'm between Four Oaks and Benson.
Frank...sorry for cluttering up your thread with this but this is where all the cool Craftsman DP guys hang out.
Thanks for the input gents.
11b30b4
GA
JoCoSawdust, welcome to the DP family and like everyone else has already said, that planetary speed reducer is really cool.
So are we going to get pics of the 100? or did I miss them already?
Also, thanks for the nod to my thread. I am glad some of the stuff I post was helpful.
BTF
JoCoSawdust
Eastern NC
Thanks Frank and 11B.
As far as joining the DP family, let's say I'm party crashing at a cousin's house. I've got 15 DPs in my collection (so far), all pre-war Sears pieces made by Atlas, Walker Turner or Central Specialties. My daily user is a Crown 150 with Vari-Slo that was well cared for by the original owner. It was plug and play when I got it home so this 100 is my first incursion into refurbishing a post war machine. I'm trying really hard not to let my "get one of every variant from period X" spill over into the post-war era as I'd have to build a bigger shop!
Here's the only photo of the 100 so far. I'm horrible about documenting my builds. I get focused and never want to stop to take pictures. I sure do enjoy and appreciate the guys that do though. I always tackle the columns first since that's the only aspect of these things that I hate. The column on this one cleaned up well and will do justice to the machine. I stole Frank's angle iron/carriage bolt bearing puller idea yesterday to pull the top bearing off the pulley. Apparently I was lucky with this machine as I didn't run into any of the issues of disassembly that some other have. The machine came apart like it was assembled yesterday. These threads were crucial to me knowing how to do it without botching something up.
I'm rambling and need to get to the task at hand. There probably won't be any in-progress pics of this thing (unless I hit a wall) but I'll be sure to post the final result.
Thanks again gents.
