Craftsman Lathe experts--please ID
Goldhawg
This craftsman lathe is up for sale soon at an estate sale. I'd like a nice metal lathe if this is a good one. What would be a good price for it? Would I be better off to wait until I can afford a nice south bend?
schor
Ajax, Ontario
How much it's worth depends on lots of things. Primarily availability of that class of lathe in your area.
That's an atlas made lathe, no quick change gearbox, looks like no chuck but there are some collets there I think, no steady rest.
I wouldn't go more than $400-$500 if it does not have a chuck and various other items.
56FordGuy
Wyoming
Yep, Atlas made Craftsman. That one looks exactly like the one I have. It appears to be a babbit bearing model. Nothing wrong with that. Atlas/ Craftsman were the first hobby lathes that the average guy could set up and use. Mine has a few limitations, mostly I wish it were a little bigger. That said it's a great lathe to learn on/ use every once in a while.
The wonderful thing about Atlas lathes today is that 90% of the parts are available new through Clausing. I had to make some repairs to the apron on my lathe when I bought it, and I got all the parts direct from them for less than used parts were going for on eBay.
I can see the tailstock on the bottom shelf, and looks like the change gears and a drill chuck as well. As Steve said, there's no chuck in the picture. You can buy them on eBay, but it's more money. It may be in the drawer?
If that's new tooling and cutters in those little boxes on the bottom shelf, that can be worth a bit as well.
I'd probably go $400-500 on it as well, but expect to spend another hundred or so buying a chuck and tooling.
454ragtop
Carver, MA
That's the little 6" swing lathe, if there are no chucks, I wouldn't pay more than $300. A 10" swing or better is a much more capable lathe. Never seen a quick change on a 6" Atlas/Craftsman.
Good luck, Jim
G
Goldhawg
There is a 3 jaw chuck, but for some reason it is not included (looks like an add'l fee).
WILD-BILL
Brook Park Oh
That is not a 6" lathe. The Compound is wrong (taller then a 6) and it appears to have a knob for power cross feed just under the cross feed dial handle.
Point out to the Estate sale staff the chuck is part of the lathe, and should be sold with it.
Also a bit behind the chuck on the table is an atlas X/Y table for a DP another nice item to watch...
And I agree at least a 10" possibly a 12, those bench legs look to be 2X6...
nine4gmc
Dallas
That is definitely a 10-12" and there looks to be a milling attachment possibly on that table with the chuck. I would mention the things on the table with the handles similar to the lathe, goes with the lathe as well. Along with the yellow tagged item by the jelly jar.
9Four, you talking about the stuff in the plastic tray at the back? I'm not sure what that is. there is also the block of something in between, and that may go with the plastic tray stuff. the tray definitely has a hand crank/lead screw of some type.
zkling
Ha ha, yea I saw that too. It looks like they have some nice stuff but I have a feeling prices will be high based on what I saw in the pics. Unfortunatly I'm booked solid those days otherwise I'd try to go and see the sale in person. Looks like a neat place to dig through though. If you do go can you let me know how much they had on the craftsman box?
Zeke
That's a quick $1000 here. I sold one exactly like it last year (2012) for 1100 with minimal tooling. The compound is correct if mine was and it worked fine. I'd make a play for the machine and everything on the table. You can sell off duplicates and bring your net cost down. I don't know where goldhawg lives, but I'd drive 500 miles to buy that for 500.
A 6" lathe has a 3" Raduis of swing,
The conduit (EMT and flex) is 1/2" dia...
That oatmeal container on the bottom shelf is 5" in diameter...
The electrical box on the wall are about 4" long...
There are 1X8 fence boards on the floor next to the 2X6" (5-1/2") bench legs...
The center of the spindle to the lath bed is clearly at least as much as the width of the bench legs...
I don't think my eye is that far off, regardless of similar features...
tdkkart
Eastern Iowa
It's a 12" lathe, I had one just like it I sold a couple years ago, It's NOT a 6", I've had one of those also, completely different.
They made 10" and 12" models in this style, the visual clue between the 2 is the raised tool post area on the compound, on a 10" the top tool post slot was at the same height as the rest of the compound rest. The 12" compound is raised 1" as in the picture.
The lead screw reverser is correct also.
This one has the plain bearing spindle, later models had timken style bearings.
I got $700 out of mine 2 years ago with 3 and 4 jaw chucks, a quick change gearbox, and a nice heavy metal cabinet.
People get all excited about the QC gearboxes, yet in reality you don't have to change feeds very often, and changing is not really a huge hassle.
spongerich
Monroe, NY
It's almost certainly a 12" For comparison, I bought a very similar one yesterday on CL in New York state for $600 with a steady rest and a set of cast iron legs.
Assuming that one is in good condition, it seems to be reasonably well tooled. If you could get it for $500, you'd be doing pretty well.
Some of the critical parts (gears etc) are Zamak... a special type of metal that's apparently designed to break when you need it most and it's impossible to repair. That makes replacement parts expensive, so make sure that it's all intact.
PS - Those pictures look familiar... you'd better hope you get there before I do. :D
G
Goldhawg
If I am able to get this lathe, what on this table do I need to try and get?
schor
Ajax, Ontario
I'd probably go for whatever is in the tool boxes if there is anything in them. I'd expect some measuring tools, hss tooling, small screwdrivers, scales, scribes, files, ...
Your getting a lathe so the 123 blocks, parallels, end mills don't help too much with lathe work. I assume you'd have to buy/bid on everything so I'd pick and choose out of those.
The tap handles and taps are useful and if they are in good shape and good quality they can save you lots of money along the way.
It's too hard to tell what some of the things on the very right are, they could be useful but not sure.
