craftsman rounded bolt remover kit
Ign
Butte Peak ND
They showed up in Hot Deals under this price several times. Maybe search for bolt-out. General concensus is that they're good. I like mine, but you gotta realize they won't work every time.
jjjrmx5
Cincinnati, OH
Ihave both sets that you hold in the one case.
I only use them once or twice a year, but for the $20 for both sets total on sale, they are well woth the money to me.
dogdog
None of them worked well when the bolt / nuts are actually stuck / rounded. Had that $70 set and that $9.99 set never worked when I needed it to.
finn
The UP, God's country
Funny this subject came up now. I just crawled out from under my 88 Chevy plow truck after using the Craftsman extractors to remove the corroded differential cover bolts.
The heads on a couple of the bolts were almost gone, but the tool worked fine.
It's been in the box for a couple of years, but I think this is the first time I used it.
rapid robert
Upstate NY
I have an Irwin branded set just like this...they have saved me a couple of times including a bunch of rusted out fasteners on a ford 5.4.
jjjrmx5
Cincinnati, OH
You might want to heat up those stubborn bolts befoer using a regular socket on them much less the bolt/screw removers.
Corrosion or dissimilar metals is often the problem, and heat or penetrant helps a lot prior to using any type of easy-out.
I use mapp, propane or the torch if not around a gas/fuel or explost=ive goodies.
Heat indutor if fussy .
Attack the corrosive issue first and the tool will work like buttah.
lakota
Western New York
Ignored the sales for this kit for years and then last year had to get out a rounded caliper 14mm bolt. Bought the small kit for the regular price of $20. The remover worked for me. Got the larger set when on sale for $10.
