Good day folks,
Had two questions:
1) need to run wiring from the panel to the sump pump in the crawlspace. The wire has to run perpendicular to the floor joists. I don’t want to drill holes in every single joist. Is there another code approved option to run it? Perhaps a conduit or metal casing wire or a busway with furring strips?
2) Crawlspace has about 3’-4’ headroom (it varies). Want to install lightening. Would you recommend low voltage led lightening all around or couple of high output led bulbs screwed into ceiling mounted outlets? Crawlspace is not used for any storage, so, not accessed frequently but would be nice to have some good lighting.
the run between panel and sump is about 50’.
No water in the crawlspace. The sump pump runs may be in Jan/Feb when water table rises from long rainy days.
Thank you!
Had two questions:
Thank you!
