Creating a simple flip flop circuit
Matt Matt
Ontario
I have a dust collection system project coming up. (I hope, I don’t have to get my technologist on board as it’s kind of a personal project .) I want to be able to start/stop my dust collection system using 12-24 V low voltage momentary buttons (similar to doorbell). Three wire control system will hold a circuit, if you add a DPDT, this should hold it. Adding another DPDT should kill it for power failure and/or shut down. A main Contactor (size 2)should be able to carry the 5 hp 1P dust collector. I’m fine with the electrical part. And the code. I’m just wondering if anybody has a simple flip-flop wiring circuit diagram using two ice cubes for controls? I’m definitely open for questioning... but I’d like to try to keep this is a control circuit! I do want to add any E stop, but that is pretty simple and not my question. Maybe engineers or technologists or electrical control wiring guys. Sorry if this is a brainteaser.
I’ll try to put to post my rough wiring schematic tomorrow for critique.
I want to use a Allen Bradley momentary button to start and stop with each press, the dust collection system. In power loss, I want the system to remain off in power recovery! I pretty much want to use HVAC Control (18g,300v)wire for the control circuit.
rockwithjason
Las Vegas
why are you not using simple 3 wire control circuits? you can do everything you want and you don't have to reinvent the wheel.
this video shows for a three phase motor but it works with a single phase motor too
mm08822
My thoughts too, keep it simple.
However, doorbell buttons and bell wire are super cheap.
These's more than one way to accomplish it.
Matt Matt
Ontario
Well it’s not so simple. I think it’ll do what I’m trying achieve.
Mr. T
Central PA
If you aren't afraid of a little programming a micro810 is dirt cheap and adds some flexibility. Price might be a wash though.
walta
Dutzow Missouri
If you have a 24 volt magnetic starter on the collector it should not be difficult to wire a pair of 3 wire control stations to it.
It is very likely your Allen Bradley buttons are not DPDT most of the starts buttons are NO and the stops are NC
Walta
ahazi
Los Angeles, CA
Look at the links that I posted (actually very clever design). It is very simple and will do exactly what you need/asked for, namely on/off control by a single N.O. (normally open) push button switch.
Let me know if you need more help.
Ariel
Matt Matt
Ontario
The reason why I want a low-voltage control circuit is;
I actually want to power this off the A battery. The system is a little more complex then I’m getting into with you guys. It is going to charge a small air compressor and the blast gates that will work pneumatically. I’m actually looking into getting momentary control relay circuit boards made. I just need to get a proof of concept first. The dust collection system may work off of a VFD to regulate CFM based on how many gates are open.... but now I’m getting ahead of myself.
My end goal is to have a simple dust collection system for idiots. One button on, one button off. One momentary stop that will reset the whole system at any part of the day, and e-stops in a few locations.
I’m about two or three days away from finishing building a silent air compressor that is going to do pneumatic part. I’ve been calling it my “the silent pipe bomb Air compressor”.
Maybe if anybody’s interested in the little air compressor I’ll start another thread. But as for now this is A 3 year Old refrigerator Freon compressor that I am repurposing for fun.
Matt Matt
Ontario
Ariel
Wow!
I really wish I found that link. One of their more complex circuits is exactly what I spent three hours trying to figure out. But it wasn’t exactly where you link me to. The link does give another link to my proof of concept. Thanks! I think number 14 or 15 is what I came up with.
http://www.emil.matei.ro/onof3.php
ddawg16
S. California
A classic example of relay logic.....
And why PLC's were created.
If it was me, I'd be doing what MrT suggested and use a Micro810....and the software is free
Or, if you're not afraid of Python....a Raspberry Pi with a relay board.
ahazi
Los Angeles, CA
Wow!
Here is another web link to essentially the same circuit:
Look down the page for "T flip-flop"
http://www.homofaciens.de/technics-base-circuits-relay_en.htm
Also a picture to how to build it if you are not into electronics and relays:
http://www.homofaciens.de/bilder/technik/relay_041.htm
I disagree with the PLC advocates for this function - if you want a simple, inexpensive and reliable way to achieve your goal this is a good way to go. I have worked on many logic circuits over the years and for certain things relays are a very good solution. You can find some very inexpensive sealed relays on eBay. Since the actual load is carried by a big relay "contactor" there is practically no wear on this little circuit. Also using simple inexpensive N.O. SPST push buttons (which you can run in parallel as opposed to SPDT or N.C push buttons) makes this a nice solution.
Good luck!
Ariel
ddawg16
S. California
Good luck!
Ariel
Good luck adding features like time delays or auto off. Yea, sure, you can do it with time delay relays.....but they cost more than the Micro.
A Micro820 has 7 relay outputs...8 120Vac inputs, 4 24Vdc inputs....and you can add more. Ethernet and serial ports....you can add an LCD display.
A perfect example of what you can do with it....automatically sense when a power tool is turned on....then automatically turn off after say 20 seconds when the tool stops.
If manually turned on, you can program it to turn off after say 10 min of no activity.
So many options....and you don't have to spend half the day running wires.
A typical AB relay will cost you $25 or more. It doesn't take long to spend as much if not more than the Micro810.
ahazi
Los Angeles, CA
I agree that if you need more features using relays is not a wise or economical solution. But... for this function you don't need AB relays. You can get 10 ea. of 12 volt DPDT sealed relays for about $20. So this all depends on price sensitivity and if this is a one off project or something else.
I will look more into the Micro820 as a candidate for my own projects.
Ariel
matt_i
I'm having a hard time visualizing your wiring diagram. As others suggested the 3 wire control is classic, the starts (NO) all go in parallel and the stops (NO) all go in series.
I don't get the need for an Estop (other than you don't trust the VFD or you fear a welded-contact..but on 24vac...?), for a NEMA-2-only system its basically the same thing, just detented and a 2-wire system but must ultimately control a magnetic device (a redundant one or the same one). An Estop backing up a VFD obviously have their purpose in industrial settings but for a personal shop its a bit of extra expense.
I am building a simple circuit for starting and stopping my phase converter from a multi room building using 3 way and 4 way switches (which ultimately go to a coil as I need a dry contact ) Its not a mag device so would have implications in a power outage but I'm OK with it.
Apologies for the College Football Playoff logo in there..doodling on my wiring diagram :eyecrazy: There are also a set of indicator lights. The lights could be push-to-test but I decided against that feature for right now.
Sample control station.
