Creeper on RaceDeck Flooring
16again
Boynton Beach, FL.
Alright, just about ready to order (waiting on closing date) my RaceDeck Floor!
Samples arrived yesterday, like them all! That said, I’m leaning towards the Circletrac. I’m in Florida so there is no need for water or snow draining down. I want the Circletrac, boss says she likes the diamond plate.
Going to be all ALLOY in color.
Any feedback running a creeper across both? Generally do all my own work on my vehicles. Have 10’ ceiling, lift perhaps someday.
For now rolling in style on a creeper. Lol
kram71
Home
Circle is easier than diamond for rolling things as far as I know.
Negen
Seatltle WA
I would imagine that creepers with bigger wheels like the bone rough rider or others with the larger diameter rubber wheels would work better than the lower profile hard plastic or metal wheels
Sent from my ONEPLUS A6013 using The Garage Journal mobile app
_Stang_
Doable even on free flow but I much prefer cardboard and HF moving blankets.
Shea
California
I use a Bone creeper with the polyurethane wheels. It rolls very easily over diamond and free-flow tiles.
rsparks64
Hill Country Texas
My bone creeper with large wheels will roll over gravel if it is not too loose. I used it on my old asphalt driveway and it worked great, while my small detailer’s stool with small wheels felt all the bumps. That creeper is almost too good on smooth concrete when you try to get off of it. I have not tested it on RaceDeck but think it would work great
SteveCh
I have areas of coin and others of Freeflow. The creeper runs fine over either, I don't even think about it. Not an issue.
16again
Boynton Beach, FL.
Thank you for all the info. Gonna grab a bone creeper. Will order the floor and creeper at the same time. Waiting on closing date. :thumbup:
CombatNinja
Two tidbits I have picked up over the years that apply here:
Things on casters seem to roll a little easier on Circle Trac than Diamond.
Given your location in hot, humid Florida, do yourself a favor and determine how much water vapor is moving up through your slab before you commit to a solid tile. I have seen some pretty gnarly mold issues in garages where solid mats or tiles were laid down on slabs that had chronic moisture issues. Just get a sheet of 10 mil plastic and duct tape a few 3' x 3' squares down around the slab before you move anything in. Leave it for a few days and then check to see how much water vapor is trapped under it.
I really wanted solid tiles as well but living in the coastal plain of North Carolina sort of forced me to go with Free flow. I was working with an existing slab and of course a vapor barrier was not put in at the time of construction. Couple of hundred bucks and 15 minutes of work at the time the home was built would have increased comfort drastically.
