CSST in a wall?
Rockhead261
For safety purposes? Yes. Per code? Check with your local Big Brother.
Make sure you ground CSST whenever you use it.
Jackfre
N CA
Ground the first fitting. Use all of the appropriate nail plates etc. they also have a termination piece for exiting the wall.
Rockhead261
Actually, you need to jumper across the pipe itself to the first fitting on the rigid pipe. CSST fitting are/can be dielectric. In other words, the CSST is isolated from the piping and creates a gap in electrolysis. You need a clamp on the CSST fitting to a clamp on the rigid pipe in order to maintain ground continuity.
ishiboo
Oshkosh, WI
That's an interesting diagram IMO.
Usually, that final connection between black pipe is a CSST appliance connector. At least here, bonding is not required nor suggested for an appliance connector.
I have all copper LP line, except a new CSST that goes up to the attic for a new furnace. I wonder if it should have a jumper around it according to code?
