Here is one I have been working on.
Here's mine
Nighttrain...where is the sawdust going? Is there a vacuum on the other side of the wall?
I'm interested in the choice between long-outfeed left vs right. Both those benches are on the right. It seems like most other tables I see are left and I prefer left also. I don't do a lot of crown molding, etc, though. Is there something about trimwork that wants the long piece on one side or the other?
CF this might not be exactly what you're looking for but it could be done without the long tables on either side. The mitee saw area is really only 30" wide and 36" tall. It houses a trash can and a planer lift. As metal scrap becomes available I will add a door to the planer area, a panel to the trash can pullout and a 4" tall drawer between the planer lift arms. It's a lot of use out of a 30" space. I found the area in front of the workbench is the perfect spot to run long boards. I use a fair amount of rough-sawn mahogany for projects and I can plane, chop and dump the dust without leaving one spot. My table saw is right behind it so it's a pretty convenient work space. I intentionally positioned the table saw 12' from the rear wall (8' panel + 2' of machinery on the rear wall + 2' standing space) and the chop saw 16' from the rear wall so it wouldn't interfere with a panel cross cut. My bench is not anchored to the wall because of the size and weight but if doing it as a stand alone I'd probably bolt it to the wall.
Please excuse the mess. I've got wood and metal projects going right now so it's not exactly 12-gauge clean.
THANKS!!
Here's mine
I've been thinking about building one with three individual cabinets high-left, lower-middle, high-right all on casters so that you could move the saw stand to the middle if you're cutting the center of a long board, or to the left or right so that you have support if you're cutting the end of a board.
You'll need an awfully level floor for the saw to work with precision.
Thats is very nice. I dont have any metal at my disposal (or at least that my wallet will allow for) but very nice none the less.
I like the portability/versatility of this!!
THANKS!!
I made one of those 6 or 7 years ago. It really is a very useful bench for everything woodworking.
^^^ very nice set up. What type of channel did you use for the saw stop?
Hi, I'm new to the garage journal but not to garages. Anyhow I've been lurking on the site for a while and this miter saw station post caught my attention.
I just finished this last week. It has been a plan sitting in the back of my mind for quite a while...
This may be a dumb question but why 2 miter saws in 1 station? I am definitely an advocate of "More is Better" but I'm just a little confused at why 2? I've seen this several places.![]()
I would like to see this alsodoes anyone have a bench with a sliding mitre saw?
