Cutoff wheel recommendation
L
LXCam
Thanks guys. Never tried the Walters but have tried the Pferd and liked them. Hum, maybe I'll have to swing by a couple places tomorrow and see if I can't get a couple of each and see what's what.
md21722
Mt Juliet, TN
Pferd may be good, I have used Norton, SAI, 3M, Diablo and Forney and the only two that have come apart on me are the 3M and Forney.... I was surprised the 3M came apart, but not really surprised the Forney did. Always wear a full face shield!
Thumper68
Duluth MN
I have been trying out the Lenox metal max for the last few weeks and am very impressed
Thread here
I have a list going of what I have cut with 1 so far you can add to that the heads of 8 Ford truck bed mounting bolts, and then cutting 5 of the bolts again so they would drop through the holes in the frame.
The damn thing is still going strong.
MJD1
Norton Blue fire is the best I have used, Walter are good as well. Thin as possible is the way to go.
lazer50
east central indiana
Im a welder/fabricator and do quite a bit of cutting.some air some plasma etc.i usually buy norton discs or the brand p f e r d.quality is comparible between the two.but last year a local welding/construction company went for sale,the owner retired and he had a seperated machinery,tool,inventory auction. I bought anything welding related.with the inventory was probably 100-150 lbs 4 1/2 cut off discs made by falcon abrasives and made in usa! Several styles the ones i use are blue talons and X p.these discs cut thru material like butter.they last longer,very easy to cut strait and they dont fly apart.i looked the company up and it seems you have to locate a distributor near you to get prices.i haven't done that yet.the prices may scare me or may be worth it judging by the performance.
John T
Hey guys its time to buy some 4.5" cutoff wheels in bulk again. I've been using these for general steel with good results but was wondering if anyone has a better recommendation url]
Lehigh valley abrasives. / good prices. Quick shipp
I like the Sait stuff personally.
Finky198
North East
Sait, Lenox, and Norton, are my go to's but I bought a lot off of CL a while back with 100+ Sait and dewalt discs of dif varieties... so far so good...
L
LXCam
Thanks again for the suggestions guys. And ya I'll be buying from Lehigh more then likely as I always have in the past.
Thought I'd point an observation out about the saits and maybe this might make a difference on the suggestions. I noticed if I maintain the cut shallow on the blade and "scrape" my way through the cut they last a good long time. But anytime I'm forced to go deep on the blade, as in let's say 60-90 degrees to the metal it eats up the blade 5x's faster for some strange reason. Normally if I'm on the bench this is never a problem. But right now I'm doing a mini tub and having to drop in pretty deep to catch all the layers of metal which has the cut relationship all over the board which I have no control over. I know in the past I've had some wheels that didn't suffer from this issue but have no idea whose they were, it was just a random selection I got at the welding supply place. And I hate just walking in there to buy them one or two at a whack since they're 3x's what I can buy them for from Lehigh by the box.
And nice write up on the blade thumper, but I prefer they have a hub (whatever that offset is called) so I can flush cut.
L
LXCam
Much appreciated folks. Never attempted the Walters however have attempted the Pferd and enjoyed them. Murmur, possibly I'll need to swing by two or three places tomorrow and check whether I can't get a few each and see's what
I have a rundown going of what I have cut with 1 so far you can add to that the heads of 8 Ford truck bed mounting jolts, and afterward cutting 5 of the jolts again so they would drop through the openings in the casing.
Hot damn, bitten by a therous (however you speel that) in my own thread. Lol
Stillridin
Lutz Florida
Norton blue. I've used quite a bit of different discs over the past 35 years. Sometimes even harbor freight just cause their so cheap. But nothing compares to the quality of Norton. Same goes for their Da paper, long board, air grinder, everything. Great product.
L
LXCam
Well by cracky I'm going to try out all these plus get some damn Walters and Pferd and this time I'm going to keep track of what I like the best. So thanks for the input guys.
1 G2728564 22021 Grinding and Cutting Wheels Aluminum Oxide 20 EA Abrasive Cut-Off Wheel, Type Type 27, Wheel Type Cutting, Diameter 4-1/2 In., Thickness 0.045 In., Arbor Size 7/8 In., Abrasive Material Aluminum Oxide, Grit 60, Grade Medium, Max. RPM 13300, Series A60S - General Purpose Cutting, Application Ferrous Metal Item ships from Zoro in 1 business day. 2.11 42.20
2 G0815306 23334 Grinding and Cutting Wheels Zirconium 5 EA Abrasive Cut-Off Wheel, Type Type 27, Wheel Type Cutting, Diameter 4-1/2 In., Thickness 0.045 In., Arbor Size 7/8 In., Abrasive Material Zirconium, Grit 36, Max. RPM 13300, Series Z-Tech, Application Ferrous Metal, Stainless Item ships from Zoro in 1 business day. 2.25 11.25
3 G1875151 66252823602 Abrasive Cut Off Wheels 5 EA Cut-Off Wheel, Wheel Type 1, Diameter 4-1/2 In., Thickness 0.045 In., Arbor Hole 7/8 In., Max. RPM 13,580, Material Aluminum Oxide, Series Gemini Right Cut, 36, Application Ferrous Metal, Gray Iron, Stainless, Diamond Knockout No, Wheel Specifications Gemini Rightcut, Type 1 Item ships from Zoro in 1 business day. 1.83 9.15
4 G3617555 DW8857 Cut Off Wheels 10 EA Abrasive Cut-Off Wheel, Type Type 27, Wheel Type Cutting, Diameter 4-1/2 In., Thickness 0.045 In., Arbor Size 7/8 In., Abrasive Material Zirconia Alumina, Grit 60, Grade Medium, Max. RPM 13300, Series Extended Performance Z60T, Application Ferrous Metal, Stainless Item ships from Zoro i
Farmall450
Marengo, Illinois
I got some off eBay, 5" in my case, I can't remember the acronym but it's something-USA, and surprisingly enough they're actually made in the USA. They last pretty dang long for the instances I hit it with an electric grinder vs the typical pneumatic one (which is use 3M wheels on).
Thumper68
Duluth MN
I e-mailed Lenox and suggested they make a cupped center wheel, because you are right the cupped center does make some cuts easier.
strength_and_power
Www.heleta.com
They have cut off wheel, flap discs etc.
All cut off wheels wear away so I have trouble spending extra for a name brand.
On a similar but different note, I went through many brands of flap wheels trying to find the best option. In the end, I concluded, rather than pay three times as much for a flap wheel that didn't last 3 times as long, I just buy 3 of the cheap discs and move on. In some cases, having a new disc more often reduced the effort I had use.
metaldad
nw indiana
i use metabo super slicers, they ARE the cats meow.
picked up a box of de walt cutting discs, used enough to get thru that days job, and threw the remainder away
have used sait, good product.
winlinmac
USA
I had a Diablo cutoff wheel which almost came apart
metaldad
nw indiana
always wear hand and eye protection.
anything spinning can hand grenade and throw shrapnel everywhere
L
LXCam
Nothing much better then grenading a blade every now and then to keep you on your toes. :D
winlinmac
USA
I've always wondered why there wasn't something similar available like a welder's face shield, facing the grinder away from you would be a partial solution if I'm not mistaken :dunno:
metaldad
nw indiana
like a clear shield over the disc/wheel?
probably because it would scratch easily and be useless in a short time
