cutting 2/2/2/4 SE-R?
MadMike78
Besides the high dollar cutters, what can the DIY guy use to make simpler?
dw1
Ky
Pair of 9" side cutters or hacksaw, sawzall. Separate the wires and cut them individually.
MadMike78
I was thinking sawzall or metal chop saw! Took kid 10 minutes out in freezing cold at Menards to cut with bolt cutters!
dw1
Ky
I have a pair of ratchet Greenlee cutters that I use, they work great, but were a little pricey. Maybe check e-bay for a bargain.
Speedster29
Oregon
Electrician installed my 200 amp panel, meter base and weatherhead today. Used a sawzall to cut the feed wires.
I have a pair of the Klein cable cutters that will cut upto 2/0 CU and 4/0 AL!
Syberia
Perris, CA
Angle grinder. Probably overkill, but it'll work. If you don't have a pair of cutters like the ones above, a tree pruner would probably work too.
Gixx
I used a "branch lopper" You know, the kind used to trim small branches off of trees ? They cut through it like butter ( all four aluminum wires ).
