Cutting 60mm Hole in Plastic
DesertG
Happy New Year guys. I am working on a car project were I need to cut a precise 60mm hole in a piece of plastic dashboard material. I am stuggling to find a hole saw blade that is not coarse or made for wood or metal. Any thoughts on how I could do this. Thank you!
PCustoms
VT
What's your tolerance?
Material thickness?
Could think of a lot of ways, each one will work great depending on exactly what I'm doing.
LXCam
Use a wood one but cut in reverse. I’d also highly suggest using a piece of metal bar stock (pre-drilled) for keeping the pilot bit centered so it doesn’t walk on you. If your piece isn’t flat then I’d suggest shaping a piece of hardwood and do the same thing.
mark#3
Could you drill a small hole in it, then use a saber saw to cut the rest of the hole out?
PCustoms
VT
Being plastic, even that won't matter if there is access to the back side.
Maybe....
Unless its too thick! Then you end up with a 60mm step in each face, and a 58mm through hike. If you drill deeper it opens to the next step size.
There's reasons why a few people have asked for more details.
PCustoms
VT
Here's a partial list of ways to cut the hole:
  • Holesaw
  • Knife
  • Step drill
  • Circle cutter
  • Jigsaw
  • Body saw
  • Router and template
  • Lightsaber
  • Smaller drill, saw etc. then sanding drum to final size
  • Laser
  • Forstner bit
  • Boring bar
  • Cnc
  • Etc.
johnre
Portland, OR
If you have a set, use a forstner bit.
If you don't, you probably don't want to buy a 60 mm (closest English size: 2 3/8) for just for this application; you'll get sticker shock.
Next choice in order of decreasing cleanliness and decreasing cost: hole saw.
PCustoms
VT
Couldn't you just turn it over and drill through the back.
No. Maybe. Depends.
Say the material is 5/8", and the steps are 1/4". If you drill to 60mm in the front, and then 60mm in the back, then you have an 1/8 on the middle that is too small. Maybe the backside can tolerate being a larger hole?
manwithtools
Lebanon, TN
  • Holesaw
  • Knife
  • Step drill
  • Circle cutter
  • Jigsaw
  • Body saw
  • Lightsaber
  • Laser
  • Forstner bit
  • Boring bar
  • Cnc
  • Etc.
Or you could measure it with a micrometer, mark it with chalk and cut it with an axe :)
PCustoms
VT
In plastic? :twak:
Maybe, if it's hard/brittle.
OP mentions having a hard time finding a non-course holesaw...this is about the only option I can think of. For under $10 I'd try it, odds are it plugs up.
I'd probably also have already drilled the hole by now
Black300zx
Elkton, Md
We're 16 replies deep and no one has suggested Oxy/Acetylene yet. I'm disappointed.
Details on what's being mounted and how much cosmetic overhang there is would be helpful. 60mm is a fairly common size for aftermarket gauges, so I'm guessing that's what might be going on here. If that's the case, a 2 3/8" hole saw should do just fine and leave a hole that is only about 0.01in too large.
nadogail
Coronado, CA
Mark a smaller circle and drill a bunch of closely spaced holes on your marked line, then clean it all up with a file.
MongoTA
CT
What a thread!
If it's somewhat rigid, someone mentioned a hole saw but cutting in reverse. Works like a champ.
If it's a bit thin or flimsy, someone else mentioned clamping it between two pieces of wood and using a hole saw. Works like a champ.
ATC
VA
Precise?
59mm hole saw, then sand it to the correct fit.
ATC
VA
  • Holesaw
  • Knife
  • Step drill
  • Circle cutter
  • Jigsaw
  • Body saw
  • Lightsaber
  • Laser
  • Forstner bit
  • Boring bar
  • Cnc
  • Etc.
  • Waterjet
  • Torch
  • 12ga with birdshot
  • Hot knife
  • Razor blade
  • Hammer & gasket punch
Zeke
2.325" is slightly oversized. If that would work there are a lot of cheap door lock boring bits available with the mandrel included. If you knocked the set off a little with a file: one, it won't grab, and 2, it would be very close to 60mm.
Gozo
Central VA
Not knowing the thickness, type, shape, or hardness of the plastic; I’ll toss this one into the mix: Diamond hole saw
I’ve done lots of tile work and have a set of these. Have used them for non-tiles stuff and some acrylic sheets. Just used the drill press on slowest setting and took my time. More like sanding through that drilling.
ambenz
NW Chicago Suburbs
...you should have mentioned you wanted to do it on the cheap!
$35 step bit, $300 router....how much do you want to spend on this hole?
I say regular old big drill bit backed by a scrap flat wood board...if you have a cheap round file, file to spec.
Man, these people love to spend our money!
