Cutting a hole in my kitchen sink ?
The Cobbler
that sounds risky . porcelain will easily chip and blow out
is it a steel or cast sink?
maybe some abrasive hole saw would work, but I'd be afraid.
I'm in the camp to get a faucet with sprayer mounted on the base already
engineer2
Chicago burbs
Porcelain enamel is essentially a glass coating (actually two coats: ground coat and color coat). The metal will either be enameling iron (very low carbon steel) or cast iron. A fine-grade diamond coring bit will drill through it. You need to find one with a pilot drill. If the bit walks around, it's going to get ugly.
You have to weigh the cost of the bit and the time vs getting a faucet with a pull-out sprayer, which is much more popular these days.
Norcal
Porcelain enameled steel is the worst choice in plumbing fixtures, look at it cross eyed & it chips, usually chosen because it was cheap, if it was stainless steel it would be easy to punch a hole with a knockout punch or a hole saw, but if are set on leaving the sink as-is, a faucet with a built in sprayer as suggested already will be best to avoid chipping the enamel.
yeldogt
This will not end well. I'm sure someone some where has the equipment to pull it off -- evening drilling a small hole in a Por tile is tricky
Steel sinks are typically not very expensive --- are you sure it steel and not CI?
Good CI are nice sinks.
ScottsGT
Lake Wateree, SC
How big of a hole? Only way I would attempt would be with a stepped bit that reams out the hole. And I would heat the area up with a heat gun first so the enamel isn't as brittle.
BD1
north side
Different faucet, hire it out, or be prepared to replace sink . Not worth it to me.
Would drilling countertop adjacent to sink be a option ??
engineer2
Chicago burbs
That would cause cracks form uneven heating. This is a glass coating.
Lots of naysayers here who have never core drilled much and are not familiar with the properties of porcelain enamel. I wouldn't hesitate to drill it with a diamond bit. Go slow and use lots of water. Just be careful when the pilot bit goes through, so the coring bit doesn't slam into the surface. If the sink lip is thick cast iron the core bit may want to wander a bit because of the stringy-ness of cast iron. A drill press would be ideal, but probably not practical. If the edge chips a little bit, no big deal, the sprayer trim ring will cover it up.
PassnThru
Bowling Green KY
if you screw it up, she can get the new stainless sink she always wanted.
That is funny for me.
I remodeled my kitchen while I was dating my now wife. I put in a cast iron double bowl white sink. It was more pricey but there are advantages - it keeps the water hotter longer - it is very sturdy - and so on.
Now we are married (about 20 years since the remodel) - and she has hinted that she now wants a stainless sink.
Why?
Apparently because a white porcelain cast iron sink is harder to keep clean.
Jokes on me - I replaced a stainless for the 'upgrade'.
mikeceli
I too will be drilling the 2, porcelain /cast iron sinks, in our kitchen. This to install soap despencesors.
I bought a diamond hole-saw, and a HSS speed hole-saw, on Amazon. I'll report back when I get it done. No idea when.
spudley
Northeast Wisconsin
I'll be waiting for a full report in triplicate.
I bought a used (looks like for a day) porcelain sink with one less hole than I need. Other than that, it's a perfect match for the existing very worn model.
The sink was $5 so I have little to lose on the attempt.
ricleh
Sacramento, CA
I have done this a couple times. I used a diamond hole saw with diamond pilot. No problems whatsoever. I just went slow and used water for cooling and lubricant.
machsnell
Northern Virginia
3rd the Diamond w pilot. You can actually drill w bit before pilot to avoid walking w core. Slow and steady wins. It will chip a little but as said it will be covered up. Seal up the cast when done.
Sent from my SM-G960U using Tapatalk
