Cyanoacrylate glue
KEH
Using Loctite Super glue in a project. That is serious stuff. directions say if fingers get stuck together use cooking oil, gently massage fingers back and forth to peel bond apart. Use rolling, peeling motion, do not pull. I was using paper towel, got a drop through that to finger and had to work fingers apart and carefully wipe excess off work. Washed carefully afterward. Recommend wearing disposable gloves. Would hate to accidently glue myself to work.
KEH
nadogail
Coronado, CA
There have been cases where a weapon was sprayed with it and tossed to an unsuspecting person and they were then photographed appearing to be brandishing said weapon.
I believe Patty Hearst may have been trapped by this trick.
K
KEH
Interesting about Patty Hearst, never heard that.
I just had pacemaker surgery, They may have used glue on the incision. There is no sign of stitches. All healing well.
KEH
rlitman
Long Island
...I just had pacemaker surgery, They may have used glue on the incision. There is no sign of stitches. All healing well.
Earlier this year I had a 12" incision closed with glue (plus several smaller ones). It really works, though this stuff isn't the same as hobby shop CA.
Really hard to find spray CA clue. I've looked and never seen it. Accelerator, sure.
Because it would be ridiculously dangerous. Think about CA mist near your eyes or airways.
kbuhagiar
Escondido, CA
KEH
Just curious - is the Loctite product superior to others?
Trying to find one super glue to keep around that is better than all the others, so I can stick with it.
mike93lx
Richmond, VA
Grab yourself some activator. It take the fast set to instantaneous. Really useful stuff
I keep both liquid and gel around, usage depends on the application. Both get used frequently
K
KEH
Haven't used it enough to have an opinion, sorry.
KEH
Zeke
No. Many companies sell it including Mohawk which I had in 3 consistencies. None of it lasts that long once opened and especially if the container is only half full. A Mohawk set might run 30 bucks. I have used the little ($3.49 for 10) HF tubes just as successfully and buy the 8 dollar (2 tubes) china stuff at Amazon. One that does work really well is called Wonderlock Tite Chair. It has additional polymers in it and lasts a bit longer in storage. 3/4 oz costs well over 10 bucks. Very thin and intended to run into wood joints. The polymers cross link and hold joints well if they are still in contact, wood to wood.
I wouldn't rate one over the other by any kind of margin except the polymer stuff,
dcg9381
Austin, TX
Never tired the polymer stuff, but when building RC things I kept 3 different thicknesses around and some accelerator. Pretty good adhesive.. How you've never managed to smell it is beyond me.. But it's not something you want to smell.
Etchase
Hawaii
There are debonders that work much better than cutting your fingers apart. Many are Acetone based, but you can read the safety sheets for other possibilities. Refrigerating opened bottles greatly lengthens shelf life.
They sold Oder free versions in the past. Not sure if they still do.
rlitman
Long Island
It's not model airplane glue. I've never even smelled fumes.
The fumes are outright nasty. About as irritating as hydrochloric acid. The curing process is exothermic, so if you use enough CA for a wet area to get hot enough, you'll see some white smoke escape.
If you're only using a little at a time, it stays cold and the smell is negligible. It's worst when I'm soaking a piece of wood through and through with the extra-thin type to harden it. As for polymer, I've got a black flexible CA designed to soak into silk model airplane control surface hinges.
Many people make the Oder less variety.
Super-Gold Odorless .5oz CA Adhesive Glue https://www.amazon.com/dp/B0000DD1QI/?tag=atomicindus08-20
I was this many days old when I learned this existed! Bob Smith has been my favorite CA source for many years now.
Pen & Wrench
Huron, SD
I had Pyloric valve repair and a hiatal hernia repaired, and the surgeon told me he used super glue to seal up the 5 small incisions they made on the front of me.
Firebrick43
West central Indiana
One of my good friends in high school and I both built and flew RC planes.
I think it was the summer between jr and sr year his parents were out of town and he was working on his plane. The bottle of med CA spilled over the desk and he leaned forward and glued his belly to the desk. He had also touched his fore head with his right hand glueing it there. And several of his fingers of his left hand were glued to the hand set of the phone.
He said he tried to dial my number over a dozen times with his pinky and not really being able to see the key pad before finally getting me.
I spent a good hour and a half dribbling acetone on him to get him free and he spent another hour doing the same after I left to get his shirt off.
slowtwitch73
Hellgate
The med stuff is dyed.. usually purple so the docs can see where it's actually going.
Other than that, there's little to no difference.... besides price.
rlitman
Long Island
The surgical CA is chemically different, not just dyed. The R group on the monomer is different, so it cures more slowly, without burning or irritating tissue. There are also medical grade CA adhesives designed for medical equipment which are chemically similar to hardware store adhesives.
like2wheel
On an as needed basis
I remember when I was a teen there was a story on the news about a woman who super glued her husband's ***** to his left leg while he was sleeping, because she found out he was cheating. The young me found it hilarious as the official being interviewed tried to sound professional as he carefully chose the words to describe the situation to a reporter. This was in the late '70's when broadcast was much more conservative.
More recently, my wife accidentally grabbed a bottle of superglue she used for her nails thinking they were eye drops. The doctor said it happens more than you'd think.
I'm allowed to laugh about it now, but don't tell her I told you.
jonesg
northern Maine/
Yup. Used it a lot while building RC airplanes.
me too,I used it too much and acquired an allergy to the fumes, esters of Cyano'.
I went to see a doctor with flu like symptoms that persisted .
he missed it and said it was just a cold...for months ?
There was an article in an RC magazine about allergies to this glue. I didn't make the connection at the time.
One morning I couldn't get up for work, a few hours later my buddy came over and took me to the emergency room, I was given a nebulizer and admitted, it took 12 days in intensive care and a biopsy to diagnose it as esynophelia pneumonia.
I reverted back to using old fashioned wood glue and actually enjoyed the hobby more because it forced me to slow down.
