Cyanoacrylate glue
K
KEH
Some people in Europe protesting various things have glued their hands to objects.
KEH
firebirdparts
Kingsport, TN
Acetone works wonders on it. I'm not too sure why they don't suggest that for "stuck fingers". Anyway it is a great wound care item as you all know.
mike93lx
Richmond, VA
Probably because acetone is not something you want to out on your skin if it can be avoided and I bet not a lot of people have acetone kicking around, other than nail polish remover
niget2002
Josephine, TX
me too,I used it too much and acquired an allergy to the fumes, esters of Cyano'.
I went to see a doctor with flu like symptoms that persisted .
he missed it and said it was just a cold...for months ?
There was an article in an RC magazine about allergies to this glue. I didn't make the connection at the time.
One morning I couldn't get up for work, a few hours later my buddy came over and took me to the emergency room, I was given a nebulizer and admitted, it took 12 days in intensive care and a biopsy to diagnose it as esynophelia pneumonia.
I reverted back to using old fashioned wood glue and actually enjoyed the hobby more because it forced me to slow down.
I always worked under a ceiling fan that blew the fumes away. It was a carry over from doing pcb soldering. I've always been under the assumption that if I can smell it, it's probably not good for me :)
Sorry to hear about the issues you went through.
Steve_P
Just curious - is the Loctite product superior to others?
Trying to find one super glue to keep around that is better than all the others, so I can stick with it.
I use the Loctite linked below. It's pretty easy to find locally- Wal Mart probably has it. The reason I use it isn't that it's necessarily so much better than anything else, but it lasts nearly forever- as long as you put the cap back on the container and store it vertically. I cut the plastic packaging so that I can remove the container, and hang it from the pegboard hook hole that's used for store display. I'm not going to say it lasts forever, but it lasts a long time- for me, more than a year. For my usage, tubes dry up shortly and I always ended up throwing most of it away.
As far as the "best" super glue, PF has done tests on various brands IIRC.
jonesg
northern Maine/
I bought a face mask with 2 chemical cartridge filters, works ok but if I had any CA on my fingers it would get me when I removed the mask, also grinding on old wood joints glued with CA produces the same gas again.
The cure was prednisone , it shuts the kidneys down, then the danger is renal failure which is fatal too .
It has to be tapered down slowly to allow the kidneys to resume function again.
some people develop epoxy allergy too.
CSRPenFab
Meridian Idaho
I used to have a side gig making custom pens for collectors. My finishing process used lots of CA glue. The process after turning/sanding a wood blank was to apply 10 coats of Medium CA, followed by a spray of activator after each coat, while the lathe was turning. Then you'd repeat it again with 10 coats of Thin CA. Then you'd polish the built up CA layers into a jewel like finish with several grades micron sanding pads. Then you'd polish it on a buffer with compound.
I learned pretty quickly to keep a bottle of CA solvent handy on the lathe bench after I glued all four fingers to the palm of my hand one day!
SlappyWhite
Upper Canada
I glued some pants on with it.... when I was a kid I was building a model F14, I ran out of the thicker model glue version so I grabbed the regular super glue. I had the model in my lap while I was working on it. Some (much) dripped down and soaked through my jeans on my thigh basically gluing them on. Fun times.
Jinks
Daytona Beach
Interesting about Patty Hearst, never heard that.
I just had pacemaker surgery, They may have used glue on the incision. There is no sign of stitches. All healing well.
KEH
Yeah, my bypass surgery was the same way. Took weeks for all the glue to come off.......... :dunno:
jonesg
northern Maine/
they sell CA debonder now.
pima67
Tucson, AZ
Years back while in the checkout line, I noticed an Enquirer headline: "Intruder superglues screaming woman to toilet seat" Didn't buy it to see if it was true.
545_days
Texas
Repairing a chipped ceramic container we use to hold keys, I managed to glue my right thumb, fore finger and middle finger together while at the same time glueing my left index finger to the ceramic container.
Thankfully my wife was home to go get acetone. We used an acetone soaked piece of dental floss to gently "saw" between my index finger and the ceramic container, and later between my fingers.
I have used super glue hundreds of times without incident, but that time was really a mess. I came out with no injuries other than her laughing at me.
rlitman
Long Island
What's the advantage of CA there?
It isn't generally used as a finish. Rather, super thin CA soaks into the wood, hardening the wood into a solid acrylic wood fiber matrix devoid of air that's as impervious as a finished piece, but with grain fully exposed on the surface so there is no layer above to obstruct it, clear or not.
manwithtools
Lebanon, TN
It stabilizes the very thin turned wood blank that is about 1/16” thick after turning and it provides a very strong and high gloss finish that really highlights the wood.
Particularly important with a highly figured or burl wood like that example. Beautiful work BTW. Wife and I used to do some of the same, not quite to that level of custom work :)
