3sonsresto
Hi All,
First post here, but long-time reader. Would appreciate your input on a question I can't find many answers to:
I've recently purchased a 60-gallon compressor that (unfortunately) came with a 3/8" air outlet on the side of it. I plan to use the comp for both sand-blasting and powder coating. I'll run at least 25' (but no more than 50') of copper tubing in order to allow for air cooling/moisture relief.
Ideally, my copper tubing will be 3/4", as I'd appreciate the extra air "storage" with that over 1/2", and have read several other posters stating they wished they would have gone larger after having installed 1/2".
I do not want to mess with removing/replacing the bung on the comp. Besides, I've read some theory that enlarging the bung doesn't really do much, anyway. Rather, I'm interested in how to best move QUICKLY from the comp to 3/4" line. I already have on hand a 3/4" hydraulic flex hose to go from the comp to the hard line, and a full-port 3/4" ball valve with one male end, one female end on it.
Does anyone make a 3/8 male to 3/4 female reducer for this purpose? I'm having a hard time finding one. Is using one even advisable in this scenario? Or, do I need to find a way to go 3/8 -> 1/2 -> 3/4? Or, am I simply overthinking everything and should I just go 3/8 -> 1/2 and keep all lines at 1/2?
Thanks!
Thanks!
