Deck Resurfacing
Buckaroo5
Central Ohio
I am working on a 28 year old deck. Tore off all the wood decking and installing Trex. Their is some variability in the height of the joists - 1/4" over 16" so I don't think that is too bad. I am installing some new joists (2x8's resting on 2x8 cross members supported by 4x4's) as my design includes some breaker boards. There is a little bowing on the new lumber but I have pulled it down with clamps and there is still elevation difference of 0- 1/4" for two joists within 6" along the 12' joist - seems like a lot and I think it would be noticeable. Perhaps this is due to shrinkage on the old joists. I could get it closer with my DeWalt planer but am concerned about what happens when new lumber shrinks. What do you guys think?
mm08822
Can you double up 2 of them with opposing crowns, and then clamp them flush to each other and nail both together while clamped? Then secure ends.
This should keep them both closer to straight between end points and being doubled up would also eliminate some bounce.
Don't forget the tape.
Skiff Builder
Southern NJ Coast
What is the height of deck off the ground?
Reason I ask is at 5' elevation, wavy decking is very noticeable to an eye of someone standing on the ground.
At 10' elevation it's only noticeable when on stairs , if attached to side of deck.
Try to eliminate at least half the variation by sorting through joist sizes before placing them or using your planer, let the air drying take care of the rest of the variation.
larry4406
Northern Virginia
At the day job, the excellent framer crown side up and then slides an 8’ level across deck joists and power plains them flat.
The lesser framer eyeballs crown only and calls it quits.
Oddly we do not apply flashing tape to top of PT joists before decking.
Buckaroo5
Central Ohio
This is what I was thinking
Buckaroo5
Central Ohio
it's only 22" off the ground. I think I will do the planing.
Skiff Builder
Southern NJ Coast
When I build a new deck, I sort the joists by actual width in 1/8" increments. Say, 9, 9-1/8, 9-1/4, etc. I than lay those joists starting from narrowest to widest. In essence the deck may slope as much as 1/2" from right to left but it is at least in plane and not really noticeable.
wssix99
Chicago, IL
I had this same problem with the same material. I built my deck just over 10 years ago. It looks OK, but I still regret not leveling off the top of the joists. The install was a ***** and water pools on the deck.
jack stand
Lakes Region Maine
Today's "dimensional" lumber seems to be more of a rough approximation of said dimensions anymore.
Thankfully it so cheap to buy!😉
PT seems even worse.
Shiftless
East Bay SFO
When I tore off the old redwood 2x6s, I installed new framing with 12 inch centers to better support the new Moisture Shield synthetic deck boards.
A neighbor installed Trex over 24 inch spaced joists and it looks like a roller coaster. 😱
here is what Google told me about Trex…
Pro-Tips for the Best Results
  • Consider 12-inch OC for standard decks: While 16-inch spacing meets the basic minimum requirements, many professional deck builders recommend reducing to 12-inch OC even on straight decks. This yields a much more rigid, premium feel and prevents bowing in hot, direct sunlight. [1, 2]
  • Picture Framing & Blocking: If you plan to "picture frame" the perimeter of the deck, or if you are doing complex board patterns, you will need to install extra framing/blocking underneath so that every board end has a joist to secure
jack stand
Lakes Region Maine
And how thick is framing lumber?
BTW, I've cut plenty of 4 x 4's that were fully treated. The center is the heartwood of the tree and will have a different appearance even if the treatment penetrated it.
My point was beyond a 2x anything you're on your own.👍
The soft juvenile center of a tree is very prone to rot.
manwithtools
Lebanon, TN
Not to beat a dead horse, but my point was that 4x4's are nearly always successfully pressure treated fully. Think of the millions of 4x4 posts that are used as fence posts and deck supports and railing posts. Sure they don't last like they did 30 years ago, but the center doesn't rot out in 5 years either. I've seen 6x6's that are fully treated as well.
My Old Tools
Hamrick Lake, TX
^^^ not true beyond about 1- 1 1/2 inches. I've never cut a 4x4 (3.5x3.5) that didn't have a 1"+ white wood un treated circle in the middle.
We cut 4x4 twice a week building wheelchair ramps. I have never seen any white wood or untreated areas. We go through a dozen a week at least.
jack stand
Lakes Region Maine
Maybe you have better suppliers or treatment companies down there in The Lone star state.👍
I don't use it for much beyond sill plates on concrete anymore. Framing on decks seems to be OK but I'll laminate 2x6's together for posts, even where a 4x4 would be. The 5/4 treated deck boards.... meh, it's fair for the money and service life.
