The short version is this: We bought a colonial home that has an attached deck on the back of the house. Starts at one end runs 14' and extends out 12'. Pressure treated frame, posts, railings, and stairs (it's off the main floor but the house is set into a grade where the basement is walk-out in the back) with an older composite decking. We want to take that deck down and put up a new deck 30' long (will stop just shy of the end of the house) and 12' deep replacing pretty much everything including the stairs.
We are planning to put a roof up over "the far" 18' portion leaving an open deck area just slightly smaller than what's there today. The covered area would also get fully screened in and we would be putting in a door that would lead from the dining room directly to the screened area.
Personally, I would have no issue using PT for everything structural AND the decking, but I would not be planning on staining or painting it in any way as I don't want to get sucked into the regular maintenance aspects that would be required. My wife would fully support everything EXCEPT leaving the wood 'bare' as she wants something that looks more color matched.
Here are the various things we're trying to be sure we understand / questions I have about the construction:
- For the framing portions (joists and such), is there any reason to not use standard PT? The expected lifespan is seemingly a fair amount less than the decking, but it's fully elevated and I would plan to use flashing tape and such to keep water away as best I could.
- How does the decking material hold up, really? What should I expect with the newer products in terms of needing to wash or similar? How does the surface hold up against harsher treatment like shoveling snow?
- Given the likely 3x to 4x multiplier of the overall cost of the project to use composite decking and vinyl/PVC handrails and such, plus the additional labor to picture frame everything, should I genuinely consider the extra cost considering we are not planning on staying in this house beyond 15 years?
- Who makes an easy to maintain screening system that doesn't cost a fortune? I've been looking at ScreenEze but expect the cost is going to be fairly high.
- Anything else that I just not thinking about here?
Anyone happen to be, or know, a contractor in central CT that will actually take on the project? Or part of it? I'm happy to take on various pieces of it if it would make it go quicker. I've already lost two months getting this scheduled because the local contractors I've spoken with aren't following through with quotes.
