Decora(tor) receptacles for residence
dwasifar
My house, like most, is wired with white residential grade receptacles, standard duplex.
I notice that some of them are yellowing, which I didn't think was even possible. They still work fine, but it makes me want to replace them. I've seen advice here not to use residential grade devices, which seems sensible. But if I'm going to do this project, I might go to "decorator" style receptacles. (All the wall switches are already either "decorator" style or else home automation wi-fi enabled devices.)
However, I haven't been able to find 15A decorator receptacles in commercial grade, in any brand. Only residential and industrial grades. Maybe some of you smarter guys can give me a little education here. If you were doing this, what would you use?
D
dwasifar
Momma dont like pulling and yanking to get her vacuum unplugged. Industrial receptacles have much harder pull out than residential. Nice feature for your 100' extension cord, but not so much for momma's stuff.
I take it you'd use residential grade, then? Do you have a brand preference?
nadogail
Coronado, CA
I buy and use the "better" grade stuff at the big box stores and like the Intermediate size trim plates.
Metal-Marc
Foothills of the Adirondacks
"Decorator"? You want to become a decorator? Grab a sharpie and decorate your own wall plates!
You can decorate light switches too if you're a Star Wars fan!
Express your inner decorator. Be unique.
adrenalinejeeper
Ventura County, CA
We went with this series of Hubbell in our new house and are very happy with them. The electrician was impressed with the quality as well. We had to use tamper resistant, but they come without it too.
These have the nice back wire feature (NOT backstab, back wire straight to the screw terminal) so they are really quick to install.
Hubbell DR15WHI
Zeke
Nice but ocd kicked in immediately because the screw slots are perpendicular to the switch.😛
As they should be. You live in a vertical world? I see horizontally and never look straight up. Same for screws. How do you clock your Phillips style?
What I tell people about screws is that they need to be tightened just so, especially in wood. When and where they stop is where they stay. No "just a little extra turn" for me. Just like torquing bolts on an engine, they rotate until the click and you leave them. You might retorque them month later, but no clocking.
As for commercial grade receptacles, you go man. I've never even had a new 89 cent one fail. I wear out extension cord ends in a year. That's where I need to put the extra money. You can't buy a good 12 ga. cord anywhere usual. Hardware stores, HD and box stores. HF are ****.
acer66
Western North Carolina
Well almost every switch, etc. I ever installed had the slots of the flat! head screw in line with the switch or receptacle slots.
If you think that is loopy wait until you see how I line up torx screws with the north star.😛
sparky 1971
Central Iowa
The difference between "tightened enough" and "cracked" is very slim when dealing with plastic (not nylon) wall plates.
Plastic plates ****, I try to use nylon midsize plates only. About half of the plastic receptacle plates I've taken off were broken. People don't understand that they are better off backing the plate screw out 1/4 turn than trying to tighten it another 1/4 turn to get the slot just right. Last summer I had to special order in a two gang combo plate duplex/single receptacle for a multi voltage copy machine/printer. What came in from P&S was plastic and I managed to break it before I even had a chance to put the stupid thing on.
nadogail
Coronado, CA
I like the appearance of the Decora devices but I don’t think they work better than the standard style.
I personally favor the mid size plates for their appearance.
Two Pump Chump
N CA
Hubbell DR15WHI
That doesn't look like TR.
Zeke
I've bought plenty of those on Amazon. Any flavor.
sparky 1971
Central Iowa
Zeke
Plenty of what? These?
I've bought a few but they aren't stocked at the supply houses. And I won't give Amazon any of my money unless it's an only option.
Nope, not those. Misread your description of a multi voltage recep, whatever that is. I can't find a pic of anything round.
dave*99
Coastal NJ
I don't disagree... I have used plenty of mid-size plates on Decora stuff. They don't break and they cover up sloppy drywall cut outs.
But I do like the look of the standard smaller plastic plates. I was happy the electrician used them in my house. None are broken and all the screw slots are vertical.
Norcal
Midsize & jumbo plates look like they are hiding a screw up, I prefer standard thermoplastic plates.
dave*99
Coastal NJ
The thermoplastic plates are nice and flat. Clean crisp look.
The midsize can be kind of flat if you are careful with torque on every screw so as not to distort the face.
Everything is a trade off.
Bert_
NW Iowa
Never really saw the appeal of decorator devices myself. I do like the better switches and devices in my own house at least. I realize most probably like residential grade in their house. I've replaced switches before because the owner died like the loud "click"
dave*99
Coastal NJ
Aesthetics aside - one thing I really like about the Decora switches is the ability to hit them with my elbow. I always seem to be carrying something somewhere and my hands are full.
ecotec
Are the Mulberry metal ones still a thing. I always preferred those.
sparky 1971
Central Iowa
It must be a regional thing. What I've always referred to as a Mulberry was a metal single gang plate with a 7/8" hole (1/2" knockout) in the center. As far as metal plates go, they are still around but for the most part, other than stainless steel, are considered more of a decoration type. The others may be out there, but I haven't looked.
