Deep Cycle Golf Cart Battery Charging
D45
NW INDIANA
So, I purchased an Ez-Go 48v golf cart for cheap...……….trying to see what I can do, if anything, to save the batteries
It was completed dead and I had to trailer it home
I removed all four batteries (heavy as sin!) and opened the battery maintenance ports, to find little (if any) water inside any of them
Batteries:
U.S Battery
Deep Cycle
12 V
US12VXZ
I bought distilled water and am trying to figure out if the water needs to be added before I try charging (bench top auto charger) them or?
Also...……..2amp or 12amp charge?
Thanks for any and all info!
mikec35
NC
Fill them with distilled water and deep cycle charge them. I’d do the 12 amp setting. They may come back enough to get it running. What’s the date code on the stickers on the batteries?
D
D45
NW INDIANA
The four batteries took 2.5 gallons total of distilled water...…….I hooked up one now to start charging
I cannot find a date code on any of the four
The manufacturer decal and labels are all in great condition too...…….they do not seem very old
mikec35
NC
When they are plugged in daily the batteries will run dry in less than a year. I’ve had that happen to me, mines a 48v with (6) 8v batteries. I got 10 years out of some Trojans that I kept charged and full of water. I think US Battery is made by the same company that makes Trojan, just a less expensive line.
Chuckster in NJ
Hunterdon County NJ
If you have a battery golf cart do yourself a favor and invest in a well made solid state "battery charger/maintainer" www.lesterelectrical.com so your batteries will last. Golf cart batteries are expensive and maintaining them will make them last for years. Lester Electric is a great company to deal with and the products are made in America....... I have installed several of the Summit 2 chargers and have been happy with them.
BTW! You will thank me later for this tip!
YukonXL04
Arlington, TX
To what line?
I just added enough to cover the plates
That... just cover the plates. And check the water often, keep the plates covered in water.
Sometimes they will come back after a good charge.
I usually charge each until the they are high enough for the cart charger to take over. For you I believe that's around 40v
D
D45
NW INDIANA
Hopefully they will charge and hold the charge
$700 for all new batteries is silly!
WisJim
Menomonie, WI
If they were low enough to need that much water for very long they may not recover. Just cover the plates before charging. You can add more water after they are fully charged. I second the recommendation of a modern charger. My batteries in my Elec-trak (6 x 6volt) have only needed water twice in the last 5 years.
mikec35
NC
Did the cart come with it's own charger? If not then see if you can get a golf cart specific charger like the Lester suggested or some type of 12 v deep cycle charger that is a charger / desulfator and maintainer. The advantage of a golf cart specific charger is that you can charge all 4 of the batteries at once. At first I would do what you are doing, charge the batteries one at a time then see if you can get the cart to run. If it runs then a more expensive cart charger would be worth it. My cart has (6) 8v batteries and I had to charge them with a 12v car charger for about 20-30 minutes each to get them charged up enough to where the factory charger would start charging them. I bought a charger that is supposed to desulfate, charge and maintain individual batteries, mine was tough because it is hard to find chargers for 8v batteries. You need to test all 4 of the 12v batteries under a load after they are charged, if any of the 4 are bad the cart won't have enough juice to run.
nadogail
Coronado, CA
You may find that the person who sold you the cart was aware of the cost of replacement batteries.
Batteries IMHO, are a consumable just like tires on a car.
D
D45
NW INDIANA
It came with this charger:
Delta Q QuiQ Model 913-4810-E3B
Yes the seller and myself were both aware the cart was not operational and needed work
X1 Mike
Flagler, Fl
What's up with the 8 volt batteries? I have a 2015 Yamaha and I have the 6 8v batteries as well. No idea why 6 are better than 4 12v batteries or if you could switch. These things are stupid expensive. Mine sits in my toy hauler in storage and I need to figure out how to keep them charged.
D
D45
NW INDIANA
One charged for 36 hours and my charger shows it was fully charged
Multi meter shows it's only at 4v though
mikec35
NC
That one is no good. If the others charge up you could temporarily sub a 12v out of a car just to see if the cart runs. If it runs you can determine next steps. I am not familiar with the battery charger you have but a quick search shows it's pre-programmed for specific batteries. You would need to get the batteries its programmed for. I'd contact the charger company and see how hard it is to program or use for different batteries. You should verify the charger itself works, they could advise on that as well.
mikec35
NC
Yeah, charging individual 8v batteries has been a challenge. The cart charger works well unless one battery goes bad or the pack has less than enough volts to start the charger, then they all discharge. I looked forever then finally found a charger that does 8v batteries. I take a day every now and then and charge the batteries individually, in-between using the golf carts charger. This one:
https://www.autometer.com/battery-extender-6-8-12-16v-5a.html
is supposed to help keep them desulfated /charged and maintained. So far it works well. I use my cart for hauling stuff on my 1.5 acres and going back and forth between my 2 garages on opposite ends of the property. I'm looking to get as much life out of these expensive batteries as possible!
Falcon67
Merkel, TX
You've never owned a battery cart then. They eat them for breakfast. And for most cart chargers, if you lose one battery after 2 or so years, it's recommended to replace all at the same time. Ours was a 36V - six 6V batteries, $600 or so a set for the cheap Sams units.
ManOnTheCouch
It’s about amp hours. You get more amp hours with 6 8v batteries. So, they don’t discharge as quickly and they give you more range. That also contributes to them lasting longer and having to replace them less frequently. As a result, it’s not uncommon for people to convert a golf cart to 6 8v batteries from 4 12v batteries.
southview
Viera, Fl
Bite the bullet and get new batteries. Sams Club Duracell are some of the cheapest and work great. I have installed them in many carts where people didn’t want to spend the money on Trojans. Also, Batteries Plus has good deals. Can order online and get a 20% coupon. Even if the ones you have hold a charge, they will discharge at a quick rate and leave you stranded when you don’t want to be. I recommend checking water ATLEAST once a month. As long as the plates are covered you can charge. Always add water after a full charge. Not before. Fill water to cover plates but leave 1/2” below bottom of fill cap. The batteries need that little bit of air space to vent gas. You can look up on Trojan website. Also, when charging, lift seat so gases can escape. The gases are what eats the terminals and cables. I coat the cables and terminals with spray from auto store. I recommend leaving charger on when ever cart is not being used. Don’t forget. Seat up when charging. The Delta charger is a great charger that will go into float mode when batteries reach a full charge. Look up the information and make sure it is programmed correctly for your batteries. Easy to do. Even in Florida heat, we get 4-6 years out of batteries following these instructions. And remember, the water will evaporate in the batteries from heat when charging and heat when using. Water level is crucial to long battery life. ��
4miller1
Oklahoma
This ^ is excellent advice. There are automatic battery water tenders avaliable. Ive never used one but they get good reviews.
mikec35
NC
Before spending $800 on batteries I would verify the cart runs. I would also verify the charger you have will charge whatever batteries you purchase since this particular charger lists specific batteries. I would hate to see you spend a lot of money on a cart that has not been verified to run and it becomes a money pit. A lot of people sell battery carts once they realize the cost to replace batteries or get them in running condition is excessive. I haven't seen 12v batteries at Sams, (4) 12v batteries at Costco will cost you around $1000
D
D45
NW INDIANA
Yes Sam's doesn't have 12v
I can get local batteries for 630
The cart ran in the fall of 2019.....i rode it alot
Maybe the charger the PO had wasn't right.....i didn't know about specific chargers
Bretny
Dutchess county NY
Not in 12V currently......6V maybe for that price
Coscto prices are high
I called a local golf cart sales/service place before I bought the Sam's club ones. They were only about $30 more per battery but trojan brand not cheap Sam's club ****.
I will agree that Trojan batteries are likely the best you can buy, but I would not call the Duracel/Deka/East Penn batteries "****" either !
D
D45
NW INDIANA
I tried charging all four batteries throughout this week
Some of a 2amp charge and some on a 12amp charge...…….and then a combo of both
36 hours should have charged one...…….but they are still only showing 4vs
One will not even charge
I guess its time to shop and buy batteries
D
D45
NW INDIANA
Odd.........I checked the 4 batteries after they have been sitting in the garage
Three batteries are at 11V and one is at 7V
For the heck of it, I installed them back in to the cart and the lights, horn, and reverse horn all work
It will not move though........so I plugged in the charger and let it charge for 24 hours
Still wont move
like2wheel
On an as needed basis
Still wont move
11.8 volts is 0% charge for a 12v lead acid battery. 12.6 is fully charged.
There is not enough current available to move the cart.
SteveCh
If you have cells of different health, you need to replace the entire set. With batteries, the system will operate at the level of the weakest battery. That's just the chemistry. You will be tearing your hair out messing with it. Bite the bullet and get a new set.
My brother-in-law purchased a gold cart for my sister with a set of batteries in about the condition of yours. The seller and he adjusted the price to take the need for a new set of batteries into consideration. Unless a set is pretty new and one battery has gone bad, it happens, replacing one battery is just not gonna do it. And a voltmeter won't tell you the health of a battery. A load test will help, but with those old ones of yours, which sat for who-knows-how-long with low electrolyte they are toast. And, no, to emphasize an earlier question, you do not want to charge batteries with low electrolyte.
D
D45
NW INDIANA
I think I need a new charger or this charger isn't good for this application....this one doesnt seem to be charging the 4 batteries good enough
They are only running for an hour then the cart won't move
dfiler2
NW Minnesota
I purchased 6 of the golf carts batteries (Mine is 36v) from Sam's about three years ago, can still go a full two rounds and drive the 6 blocks home:) I'm very happy with them, just bite the bullet and buy new, it's well worth it.
