My wife has a known issue with her kia (2013 sorento) in that the moisture build up in the evaporator accumulates and causes a pretty strong odor. This i found is because kia apparently doesn't find it worth while running the blower motor after key off for a predetermined period of time to dry it.
My question is regarding a delay OFF relay (if such a thing exhists) or a solid state timer that would be able to power the blower motor for a set timer after the key is turned off.
I need to wire it such that normal power is supplied during normal conditions then when key is off it only supplies power for around 2-4 minutes. Id like to be able to choose something that isn't full battery say 5-8 volts but this is secondary and not anything I'm overly worried about.
I appreciate any input on what is available as im down to the thought of a turbo timer wired directly to the blower motor for accessory/ignition power but i figured I'd ask first, also yes I've told her to turn the ac off but of course a minute of being uncomfortable is just unbearable in this day and age
