If you pull the garter spring ( above the top bearing) out of the way, you'll see a thing key; remove that , and the top, splined portion of the spindle can be removed. Then all you do is unscrew the Allen head screw retaining the bearings- it should slide off with hand pressure, but you may need to scrub off the dried grease to get it apart.
-James Huston
