RegalX
Picked up this Delta belt/disc sander today off CL for $60....
Model 31-460 it seems to be built pretty decent, heavy cast base, 1/3hp, 4amps, etc... It came with a bunch of belts and discs. It runs fine, but it seems very loud, the drive bearings feel smooth and I took apart the tension end and cleaned up and lubed the shaft and bushings. Perhaps some rubber feet would help, but it just doesn't seem to run super smooth.
I'll only be using this for metal, would there be any advantage to slowing down the speed? currently its a 3450RPM motor.
Is this a solid piece? Made in Taiwan, pretty sure it's from the 90's...
