Delta drill press sizing
dacalkins
What makes a 14 delta drill press a 14?
u2slow
BC
You can drill a hole in the middle of 14"-wide material. Or in other words, the machine has 7" of reach.
whateg01
doo dah, kansas, usa
Is the history behind that measurement somehow tied to lathes? Lathes are spec'd by their swing, or iow, how large of a workpiece can be put in the spindle. It seems an odd thing to use to measure a drill press even though that's how it's been done for probably forever.
slowtwitch73
Hellgate
How else would they do it? Machine capacity's.. nothing special to lathes.
whateg01
Something more logical, like the size of the work that can fit between the CL of the spindle and the column would be much more logical for a drill press. Much like the measurement RTM referenced on a bandsaw, the throat depth.
JEFinCLE
Medina Ohio
The band saw / drill press comparison doesn't quite work. A band saw is cutting, so the capacity of the throat is the most logical specification...you can't have anything larger than that as your result or remove anything larger than that as an offcut.
A drill press is putting a feature (a hole) in a plane. Diameter gives a good visualization of what you can do. Actual reach would work just as well, but apparently the marketers got possession of the spec sheet in the very beginning of drill press history and knew that bigger is better. If you are more comfortable with actual reach, learn to divide by 2.
slowtwitch73
Hellgate
That is what they do.... cl of spindle to edge of column.
